I've used DScaler to capture from analog source to a 4 hour HuffYUV compressed AVI. I didn't think to enable any log file output that may have given information about dropped frames.
Is there a way to analyze the Huffyuv AVI now to count how many dropped / invalid frames are in the entire 4 hour file? (without re-capturing and enabling log this time?)
If they were truly dropped/skipped, you can just calculate how many you should have had, subtracting how many you arrived at.
E.g. 4hours exactly @ 30fps = 4 * 60 * 60 * 30 = 432,000 frames. If you count 431,500 you dropped 500 frames.
If frames were dropped AND duplicated, you have no way of knowing unless you have either:
1. Visual timestamp/timecode onscreen
Or
2. Container metadata that show each frames' original capture/presentation timestamp (most generate them anew, so not likely).
*You could luck out if you have a continual single shot that has continual and regular motion in it, or a continual (near-) still shot. Then you could run a discontinuity test in avisynth. But that won't work properly on a multi-clip or edited scene capture, as it doesn't know the difference between an intentional and an accidental discontinuity.
Or, you could re-capture this time enabling the log.
ScottLast edited by Cornucopia; 2nd Jan 2020 at 00:20.
are there any programs that can analyze frames, and guess aspect ratio?
By codemaster in forum RestorationReplies: 6Last Post: 10th Oct 2017, 00:03 -
Dropped frames upon USB connection event
By Brad in forum Capturing and VCRReplies: 9Last Post: 4th Jul 2016, 20:03 -
Catalyst Multimedia Center - how to tell if frames are dropped?
By justin81 in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2015, 11:51 -
Dropped frames
By g_randybrown in forum Newbie / General discussionsReplies: 2Last Post: 18th May 2015, 11:01 -
By zxcvfsdg13dvw in forum Video Streaming DownloadingReplies: 3Last Post: 21st Mar 2015, 04:42
