Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Sep 2012
    Hello,
    I only burn dvds for fights so I dont know a whole lot about the subject. But from what I know, having a HD video (1280x720) file results in video quality loss when transferring to dvd. I use convertx2dvd4. Do I have to use blank HD dvds to preserve the quality?
    Also,
    How does a 2004 panasonic es30v dvd recorder/ vhs compare to a current dvd burner from a lenova edge pc?
  2. Originally Posted by tysn View Post
    But from what I know, having a HD video (1280x720) file results in video quality loss when transferring to dvd.?
    Yes, a considerable quality loss. That's because it's not "transferred" to DVD but completely reencoded to the lower 720x480 DVD resolution.
    DVD video isn't HD but standard def using the MPEG2 video codec. Here, read What Is DVD.
    Give a try to AVSToDVD and see if you like the result.
    Once you get a DVD you're satisfied with you should burn to disk using the freeware IMGBurn.
    Jul 2007
    I assume and hope you mean "flights" and not 'fights". As manono stated, DVD-Video is SD resolution 480p or 576p max. If you want to retain the 720p resolution (you'll always lose quality when you convert to any format) you have to either burn a AVCHD DVD (essentially a mini Blu-Ray) or a Blu-Ray disc, neither of which will play on a DVD player.
    For $50-100 you can get an Android tablet that will likely play your files directly. No conversion or quality loss. Yes, it may be a bit pricey for you, but the savings in time and quality DVDs, currently only Verbatim AZO discs are readily available, will likely cover the costs in no time.
    Sep 2012
    Thank you kindly
