Good morning,
I would like your support about the way to stream via VLC a flow hosted on IPCAMLIVE.COM
The Address of the camera is:
https://g0.ipcamlive.com/player/player.php?alias=1231231231
but when I use VLC to play it as network link, it does't work.
Which one should I set as IP address? The stream is public I can play on it on the browser.
Thank you!!!
I also need to play the stream that is embedded in a webpage via the ipcamlive plugin from a VLC-based plugin.
All I have is the iframe code, containing the camera unique identifier:
Any ideas?HTML Code:<iframe src="https://g0.ipcamlive.com/player/player.php?alias=5b2b8547450ee&autoplay=1" width="800px" height="450px" frameborder="0" allowfullscreen allow="autoplay; fullscreen"></iframe>
Use a browser's Developer Tools (press F12, go to Network tab) to get the m3u8 link. For example this ipcam:
https://g2.ipcamlive.com/player/player.php?alias=5da01cf4792c7
gives this m3u8 link:
https://s27.ipcamlive.com/streams_timeshift/0a5f6011085e79b7d/stream.m3u8
You can play that link directly in VLC. Or use a program like youtube-dl to download the video.
Another:
https://g3.ipcamlive.com/player/player.php?alias=myetts
https://s40.ipcamlive.com/streams/28fgsa70w6eirboo5/stream.m3u8Last edited by jagabo; 9th Feb 2021 at 06:59.
You, Sir, are a genius and a life saver!
Your method works like a charm.
Thank you so very much!
vlc stream does not play
By serejka in forum Video Streaming DownloadingReplies: 13Last Post: 25th Jul 2019, 07:50 -
Ripping IPTV Stream links from a website and play it in VLC
By yenchenje in forum DVB / IPTVReplies: 0Last Post: 28th Dec 2018, 06:27 -
MPEG 2 Extension for VLC? (VLC can't play its own recordings?!?!)
By gastrof in forum Newbie / General discussionsReplies: 17Last Post: 16th Dec 2018, 23:06 -
Stream Manoto via VLC
By Mumba in forum Video Streaming DownloadingReplies: 4Last Post: 17th Sep 2018, 12:20 -
VLC cannot play MPEG-2 (.mpg) file (VLC cannot identify the audio or ...)
By Jeppe in forum Software PlayingReplies: 6Last Post: 30th Jan 2018, 19:47
