I'm looking for an easy-to-use DV splitter that lets me load a large DV file (e.g. testfile.mov), identify frames where I want to do a split via GUI and be able to split it into a series of files (e.g. testfile-clip01.mov, testfile-clip02.mov etc...). I've found a few options but had a lot of trouble getting them to run on macOS Catalina on a modern Mac. Any suggestions? Prefer something easy to use (vs. setting up avisynth etc.) since I would like to set something up that my parents can use.
For DV, and if Mac is a must, best to get a legacy machine.
First, Catalina only supports 64bit apps, which cuts out just about all of the DV-era tools. And Mac never was great with DV other than straight capture & simple edit (except for the pro apps).
Scott -
Thread moved to the mac forum where you can get more help.
Best media player(s) on MacOS?
By vidblue in forum MacReplies: 4Last Post: 27th Dec 2019, 03:48 -
Which version of Xvid4PSP can I use with macOS 10.13.6?
By 12gage in forum Video ConversionReplies: 0Last Post: 30th Sep 2019, 08:50 -
Authoring DVD on MacOS High Sierra
By erikeriksson in forum Authoring (DVD)Replies: 7Last Post: 29th Jan 2018, 04:51 -
Using a DVB tuner from a macOS application
By lelegard in forum DVB / IPTVReplies: 5Last Post: 29th May 2017, 13:06 -
Can someone please help me with a splitting problem
By RBCC in forum EditingReplies: 4Last Post: 5th Nov 2016, 09:59
