Hi guys,
I received the wonderful Om shanti om (2007) by Farah Khan, with Shah Rukh Khan and Deepika Padukone.
[Attachment 51278 - Click to enlarge]
It is really a marvel, you should watch it someday.
As there are only English subs, I wanted to convert it into mkv file, but then it became not readable (to watch it on my TV). It still is watchable on a computer, of course.
The only way to reintroduce French subs is to make an AVCHD structure with tsmuxer, and read it on my stand-alone Sony BDV-N590. That works, but is not satisfying (the audio file is not too good).
I tried also my EMTEC TV-box, but the file cannot be read.
And finally, on my Nkbox, I got a beautiful image, but the audio is not sync.
So, what I would like to do: make a mkv file (and join ass subs, this part is easy), in order to read it with any of my devices.
But mkvmerge creates a file that seems to be a sort of slow-motion picture.
How can I proceed?
Here is the Media Info:
General
Complete name : G:\Formats Blu Ray\Om shanti om.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 36.1 GiB
Duration : 2h 49mn
Overall bit rate : 30.6 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : VC-1
Format profile : Advanced@L3
Codec ID : 234
Duration : 2h 49mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Audio #1
Menu ID : 1 (0x1)
Format : TrueHD / AC-3
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 131
Duration : 2h 49mn
Bit rate mode : Variable / Constant
Bit rate : Unknown / 448 Kbps
Maximum bit rate : 5 643 Kbps / 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 2h 49mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 542 MiB (1%)
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 2h 49mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 232 MiB (1%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
If you've got an idea, it would be welcome. If not, it doesn't matter: I wish you to have a very great time during the New Year's Eve!![]()
Appears you are just doing remuxes
VC-1 and THD could be problematic for your devices
I need a converted for this format
By kacheekfreak09 in forum Video ConversionReplies: 6Last Post: 18th Aug 2018, 10:55 -
Avchd
By Ray Greenall in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2017, 21:21 -
What could be the problem behind this converted video?
By Unknown01 in forum Newbie / General discussionsReplies: 5Last Post: 18th Oct 2015, 19:56 -
TV will not read extracted Vobsub but will read Vobsub I create....
By Borracho in forum SubtitleReplies: 13Last Post: 20th May 2015, 19:49 -
SubPics Converted to Images
By sambat in forum SubtitleReplies: 4Last Post: 2nd Apr 2015, 11:22
