I have made a mpeg1 file with my hardware mpeg TV tuner card (source from DV s-video). 352x288, 1150 kbit/sec, 25 frames/sec. The video quality from viewing the mpeg1 on windows media player is ok. After i burned the mpeg1 to VCD using nero, i found that the quality of VCD is a lot worser than viewing on the media player. What have i done wrong? how can i improve the quality?
Thanks a lot!
Playing the file on the Mediaplayer before and after burning should look identical. So, try playing the .DAT file with the media player from the VCD. If you're only playing the VCD on a DVD player and a 32 inch TV, then of course, the VCD disk is doing to look pretty bad compared to a postage stamp video on your PC monitor.
Hardware Mpeg-2 or Software ?
By video80 in forum Capturing and VCRReplies: 24Last Post: 7th Mar 2012, 20:25 -
Hardware MPEG 4 Encoders: Worthwhile?
By darkarn in forum Capturing and VCRReplies: 6Last Post: 29th Jul 2010, 19:16 -
Hardware MPEG-2 encoder cards
By cybertheque in forum Video ConversionReplies: 20Last Post: 20th Oct 2008, 19:51 -
What hardware do I need to go from VHS to Mpeg (or avi)?
By RichTJ99 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2007, 00:54 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 07:52
