Xfinity's X-1 cable box does not have composite outs so I cannot connect my Slingbox 500. Frontier Factory seems to be the only converter that also includes an HDMI output so that both composite and HDMI signals are both sent to the Slingbox. I really don't want to spend $80 for the device but all other converters that I have seen do not have the HDMI out. Any suggestions?
Get a $20 1x2 HDMI splitter and a cheaper HDMI to component (composite?) converter.
Just pointing out that you say component in the title and talk about composite in your post. A bit confusing.
Edit: I see jagabo caught it too. -
Don't you have to be careful to be sure the splitter strips the cable copy protection before feeding the signal to the converter?
Edit:From what I've read, Xfiinty's signal is definitely protected and either the splitter and/or the converter has to be able to strip the protection. Not all do.
I used to use a Slingbox, but found too clunky and slow. I'm on Spectrum and just recently found out that their online viewing apps allows me to watch whatever I've recorded on my DVR. No need for a Slingbox. I would think Xfinity has a similar app.Last edited by lingyi; 28th Dec 2019 at 13:33.
I really don't care about watching dvr'd shows. I need real time remote viewing.
You can use Xfinity's app for streaming live TV.
"Watch anywhere, on any device, any time you like
Stream live TV plus thousands of shows and movies with Xfinity On Demand."
https://www.xfinity.com/stream/
I didn't mention live TV streaming in my other post because I thought that would be assumed to be a standard feature. -
HDMI to Component Converter
By cottage in forum Newbie / General discussionsReplies: 5Last Post: 24th Jun 2019, 17:38 -
The best HDMI to component adapter
By mol3000 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2017, 17:59 -
HDMI to Component Conversion
By silvercbx in forum Newbie / General discussionsReplies: 10Last Post: 7th Sep 2016, 15:38 -
HDMI to component for HD PVR
By edowty in forum Capturing and VCRReplies: 10Last Post: 4th Aug 2016, 11:52 -
Composite/Component/Svideo to HDMI converters?
By adrianle in forum Video ConversionReplies: 7Last Post: 13th Mar 2015, 10:32
