Hopefully this hasn’t been posted before (I searched and didn’t find anything on here). Just this evening my families Vizio Smart TV’s screen started flickering; the display kept turning on and off. We didn’t change anything about the set up. It just started happening on its own while we were using it. We checked different feeds including TV, Blu-ray, and the Amazon Fire, and it was giving us problems with all of it. At first there were certain points like the main menu where it wasn’t giving us the problem, but it progressed and got worse. We checked the connection cables and my dad even changed one of the cables. We also tried turning it on from a different power source as I understand it. I checked online to see what I could do and we tried most of the options. We even did a hard reset to take it back to its factory settings. It’s definitely a problem with the TV itself, it seems. I fear it may just be dying because we’ve had it for a good several years and use it often. I just figured it couldn’t hurt to ask on here if anyone else had any other ideas, just in case.
"They will walk after the LORD, He will roar like a lion; indeed He will roar and His sons will come trembling from the west." - Hosea 11:10
Sounds like the tv has a issue,not worth fixing.
Help with filters for flickering in .ts file
By bar72 in forum Capturing and VCRReplies: 6Last Post: 10th Oct 2018, 12:35 -
flickering aliased lines
By tom_nito in forum EditingReplies: 8Last Post: 29th Jul 2017, 18:54 -
what causes this flickering after encoding?
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 24th Feb 2016, 15:19 -
PAL flickering
By multitech in forum EditingReplies: 11Last Post: 29th Sep 2015, 12:06 -
Flickering still image on export
By theisdk in forum EditingReplies: 10Last Post: 27th Aug 2015, 18:23
