In the past I have used a Canopus ADVC-110 to capture Hi-8 and VHS material using WinDV. It always has worked flawlessly. Recently (after several years of not doing any) I tried to capture a VHS tape. During the entire length of the capture, the content showed in the preview window of WinDV as expected. Upon playback, the content showed fine for 15 or 20 minutes, then changed to a static picture of a bunch of colored squares, which remained for the remainder of the capture. Same result when trying a second source tape. Any idea what this could be?
Results 1 to 14 of 14
Failing hard drive? FAT file system limitation? A short in the firewire cable?
some windv quirks - needs to be run as admin, needs to be installed somewhere other than in a c
rogram files folder. discontinuity threshold should be set to "0", or it sometimes gets "stuck". set max avi size to 1000000.
Did you check the vcr to see if it was working such as not needing a cleaning?
You don't have a proper workflow.
any old VCR > DV box will yield low quality, often uncapturable and unviewable video.
What you're experiencing is not unexpected.
All the suggestions about corrupt HDD, WinDV settings, dirty VCR, etc, is unlikely to change this. Those are far less likely than simply having a quality chain of hardware to create a proper workflow for VHS and Hi8 capture.Want my help? Ask here! (not via PM!)
Thanks to all for taking time to respond. Max AVI setting is high enough, discontinuity is 0, hard drive is okay, etc. I'm still not sure why this is happening. Like clockwork, it craps out just short of 20 minutes into the capture. Lordsmurf, I'm not sure I understand your comment regarding proper workflow. The fact that the capture fails at almost the exact same time point in the capture is what I find most peculiar, and would seem to weigh against this being a hardware issue. I have used the Canopus and WinDV to capture analog video many times in the past without incident and with acceptable results. This problem came out of nowhere.
It still sounds like false Macrovision detection to me. Some timing irregularity on the tape is interpreted to be Macrovision and the device intentionally messes up the picture. Try to start recording a minute or so after the irregularity.
That sounds reasonable, but I have tried three different tapes and this issue happens around 18 or 19 minutes into the capture on all of them. Plus, I have (I think) set the ADVC-110 to ignore Macrovision.
18-19 minutes of DV is remarkably close to 4GB. Have you definitely ruled out a maximum filesize problem?
dying advc? sounding more like a hardware problem.
Turns out the problem was not in the capture, but the playback. When I played it back in WMP and Corel VideoStudio it was fine. For some reason VLC was crapping out after 18-19 minutes. Thanks to all for the responses, though.
Canopus ADVC-100 vs. ADVC-110 vs. ADVC-300
By TrackingError in forum Capturing and VCRReplies: 36Last Post: 16th Jul 2021, 11:19 -
What Is The Best Lossless Video Capture Card as of Mid-2017?
By end-user in forum Capturing and VCRReplies: 126Last Post: 11th Aug 2019, 05:35 -
Need advice on optimal AVS script for VHS captures (with ADVC-110)
By Snakeforhire in forum RestorationReplies: 30Last Post: 5th Jun 2019, 10:51 -
What's wrong with Canopus ADVC 110/55?
By Maris 55 in forum Capturing and VCRReplies: 26Last Post: 13th Jan 2019, 11:58 -
Analog input with ADVC 110
By Knientje in forum Capturing and VCRReplies: 6Last Post: 28th Dec 2018, 03:41
