  1. I wish to run AviSynth+ on MacOsx but I saw two method: PlayOnMac and wine. I try PlayOnMac but the AviSynth+ installation report a error at the last step! I try wine as well, install success but AviSynth+ functionality sounds like not good.
    Any suggestion to use AviSynth+ on MacOsx?
  2. Member stax76's Avatar
    Nov 2009
    On thin ice
    Maybe consider VapourSynth, it's generally portable though most VapourSynth developers use Windows.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Thread moved to the mac forum where you can get more help.
    Feb 2006
    did you try this tutorial ?? - http://avisynth.nl/index.php/HOWTO:_AviSynth_video_processing_with_WINE
  5. Yes, I just following this instruction, then when I click the AviSynth+ install finish button, below error dialog popup:
Name:	Screen Shot 2019-12-26 at 12.23.16 PM.png
    Feb 2006
    try this install version tutorial - https://www.animemusicvideos.org/forum/viewtopic.php?t=125120
