I am copying a .DAT file from a VCD to my hard drive by dragging the icon from the E: to C: drives. This is usually no problem. With this new VCD it is apparently copying the whole file and after 9 minutes when there are only 5 seconds left, an error message pops up telling me that the computer can no longer find the file (AVSEQ01.DAT), perhaps because it has already been moved or deleted.
Is this some kind of block or protection? Any way to get around it?
This is probably because there is an unrecoverable error on your VCD.
In any case, you should use VCDGear to extract/convert the DAT file on a VCD back to a standard MPEG file. This takes no longer than copying the file, fixes corrupted bits of the MPEG and you don't loose any quality.
Regards.Michael Tam
w: Morsels of Evidence
Copying From Harddrive Failure
By Teac23 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2010, 13:19 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 00:30 -
Need some help with new ps3 harddrive problem
By f-zer0 in forum ComputerReplies: 5Last Post: 22nd Jul 2008, 06:38 -
the weirdest harddrive/ripping problem ive ever seen
By ted demen in forum Newbie / General discussionsReplies: 12Last Post: 10th Feb 2008, 21:20 -
DVD--HardDrive problem
By electricsguy in forum Newbie / General discussionsReplies: 7Last Post: 24th Jun 2007, 04:14
