I have a big job to do.
I found my old collection of decrypted DVDs with certain tv show. Literally 88 .iso images. On each image there are 3 episodes, with 3 audio tracks and subtitles.
I want best possible quality, only one audio track and no subtitles. Keeping chapters also would be nice. Obviously it's important to set some automatic filenaming. There's no info on DVD about titles, they're literally just TITLE 1, TITLE 2, TITLE 3.
I don't know if it matters but they're
RESOLUTiON.......: 720 x 576
FRAMERATE........: 25.000 FPS
Can be H.265 but preferably H.264.
I think VidCoder could do it, but I can't do it without help.
I have a not so old PC with i7-7700, 16GB RAM and GTX1080 so there are Intel QuickSync and NVidia CUDA.
Many thanks in advance!
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
The best possible quality means remuxing (placing the video file into another container like .mkv) and not encoding to another format like h.264 or H.265 which will always result in some quality loss. MakeMKV (you can remove unwanted audio and subtitles) is recommended to remux which should take less than 5-10 minutes per disc. You can't rename the files directly with MakeMKV, but you can use Lupas Rename to batch and number the files.
Not only will remuxing retain all the quality of the original file, but it's significantly faster than encoding. Also, IMO the space and cost savings by encoding is trivial. 88 DVD-9s = 704GB. If you shrink the file by 50%, you've saved 350GB. Even if you're not the U.S. where hard drives are going for $<$20 - $40/TB, you're looking at a savings of <$20 by encoding to a smaller format. -
Your job is big, but I've done 100+ episode (Asian series) remuxes and renaming projects a number of times. You've already done the most time consuming part, ripping the DVDs, so remuxing will be much quicker. I just did a remux test on a DVD-9 .iso with 9 episodes and it took less than 2 minutes to complete with MakeMKV. Add a couple of minutes to choose the audio and subtitle plus batch renaming and the entire process was less than 5 minutes.
Edit: FYI, one of the nice things about remuxing vs encoding is that the speed isn't bottlenecked by the CPU. About a month ago I did test for a thread on this forum. I ripped the same Blu-Ray on two vastly different systems, An i7 tower and an A6 AMD laptop and remux times were virtually the same, ~40 minutes on both systems. A DVD took ~10 min.Last edited by lingyi; 25th Dec 2019 at 17:55.
I would look at a batch job using mkvmerge. The batch job would depend on how the DVD is authored. If the three titles each is in a titleset it's pretty strait forward as the appending of more VOB files is automatically ,eg
mkvmerge -o iso2_out3.mkv G:\VIDEO_TS\vts_03_1.vob
would append all VOB files in vts03 in case there is more than one.
If the three titles are in the same titleset you'll need to split the file.
https://mkvtoolnix.download/doc/mkvmerge.html -
Another advantage to remuxing using MakeMKV is that you can easily run multiple sessions at once. Especially easy since you have the .iso(s) on your hard drive already. I just did an experiment on my system with 32GB RAM and could barely keep up with four instances of MakeMKV running. By the time I loaded the fourth .iso into MakeMKV, the first instance was done!
There is an issue with doing it this way. The default filename for MakeMKV is Title01, Title02, etc and you have to be careful not to overwrite the previous file. To prevent this, setup a series of new sequentially numbered folders and point your output there. So you'll have Folder 1 with Title01, Title2, Title03, Folder 2 with Title01, Title2, Title03, -
Thank y'all but this process (remuxing?) is going very fast, and renaming is the biggest pain in the @$$.
Isn't there a tool that'll on-the-fly rename files? Based on date of creation/modification, or title of dvd image file (i named them DVD01.ISO, DVD02.ISO etc...). Now I don't really care about seasons and episodes, it could be literally 001, 002 etc...
Many thanks in advance! -
You should probably rip all the files to their own folder (each dvd have it's own folder?) and then bulk rename them. You can use something like Bulk Rename Utility to batch append the folder names to the files within the folders as a prefix/suffix/whatever you want.
Content from various TV episodes in ripped ISO's VOB files
By kingmustard123 in forum DVD RippingReplies: 6Last Post: 29th May 2018, 15:37 -
Why can't DVDFab rip/see all episodes on my retail DVD-DL disc ?
By Subzero11 in forum DVD RippingReplies: 11Last Post: 19th Aug 2017, 12:13 -
multi images lines subtitle
By Ahmed Maher in forum SubtitleReplies: 3Last Post: 28th Jan 2017, 21:26 -
What do you use to convert AVI or MP4 to DVD ISO images when DeVeDe fails?
By rocksockdoc in forum Video ConversionReplies: 9Last Post: 25th Aug 2016, 22:00 -
Batch Convert - ISO/DVD to MP4
By joepic in forum Video ConversionReplies: 12Last Post: 26th Feb 2015, 13:09
