I have a bunch of Sony Digital 8 tapes that are at the end of their life and I need to transfer them to DVD. I have a 2012 1/2 MacBook Pro laptop with Thunderbolt. I have the cables and thunderbolt adapter.
What is the best way to save my tapes with minor editing to a DVD disk?
I want to maintain the full quality of video and sound on the tapes. Can iMovie put out the quality and size of movies (up to 60 min)? I don't want to be an expert video editor. Just cut out junk video and save the rest in full quality. I would prefer not to have to buy Final Cut pro as that is $400 I prefer not to spend.
Ideally, I would be able to take the data off the DVD in future to edit further. I am willing to buy some software and hardware if needed.
Thanks for any help.
Last edited by New archiver; 25th Dec 2019 at 00:27. Reason: Saving video from 16 year old tape
Welcome.
I think your computer will do just fine. I recently did the same with ~36 Sony analog 8 mm tapes (of my children’s childhood) using Roxio easy VHS to DVD for Mac. The converter came with its own software. I did not use iMovie to edit any of the videos, but it is easy to use. There iMovie tutorial videos out their to purchase (I haven’t done that yet). But you shouldn’t need that Roxio hardware since your videos are already in digital format. My camera no longer functioned (the circuit boards go bad after a while), so I had to buy a rebuilt Sony 8 video player on eBay. Google is your friend on importing and editing, and burning the videos to DVDs, though I’ve read that burnable DVDs also have a life expectancy. In addition, I really didn’t want to buy 150 burnable DVDs, so I simply saved all the videos (67GB) to my 1TB hard drive, then dragged them all to 128GB SD cards (plugged into my MBPro’s built in SD card slot). Now, all 4 of my now grown kids have digital copies of all of their childhood memories.
Good luck. -
If you want to create a DVD that you can watch on a DVD player, you will need to convert from the original DV format to MPEG-2. There will be some amount of digital generation loss.
If you just want a data DVD, good software can do cuts without any quality loss. Not sure whether iMovie supports lossless cutting though.
digital video file to mini dv tape
By devdev in forum Video ConversionReplies: 10Last Post: 1st Jun 2019, 17:00 -
Newbie looking for some help with edits!!
By crotalusjbc in forum EditingReplies: 2Last Post: 18th May 2017, 09:14 -
Archiving old VHS footage to digital. Home deck or computer?
By Gil T Remnant in forum RestorationReplies: 4Last Post: 8th Aug 2016, 18:35 -
Need help with indexing/archiving AVCHD mini hdv tape
By Orion5150 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2015, 13:40 -
Is there a way to make very minor text edits to a SUP or SUB file?
By haggis999 in forum SubtitleReplies: 18Last Post: 1st Apr 2015, 17:48
