I have the DNxHD codec installed on my Windows workstation. When I output from Premiere Pro I choose DNxHD50p 75 which shows output size 1920x1080. Fine. But when I look at the output file it reports to be 1440x1080.
Very confusing. I need the output file to be 1920x1080.
Installed DNxHD ? This must be an old version of Premiere? It comes with many flavours of DNxHD/DNxNR now
In the options, if there are the letters "TR" in the name, that indicates "thin raster" or horizontally compressed . 1440 instead of 1920. Use the ones that don't say TR -
IIRC, in those older versions, it didn't even have you specify - if you chose a particular resolution option and gave it one of the lower bitrate suboptions, because it knew it needed to maintain sufficient quality, it automatically chose a TR version for you.
And that was how it was supposed to work.
TR versions will still play at the intended resolution (1440->1920, 960->1280), they're just anamorphic. If this is unacceptable to you, perhaps choose a higher bitrate.
cant export to dnxhd in blender
By oduodui in forum EditingReplies: 4Last Post: 14th Jun 2019, 19:52 -
Bitrate and file size problem
By Aircraft in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2018, 19:36 -
FFMBC - problems converting to DNxHD 185 10-bit codec
By Benoit in forum Video ConversionReplies: 1Last Post: 18th Aug 2016, 00:43 -
AVStoDVD File size problem
By Drastics in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2015, 18:44 -
Do DNxHD codec is free for commercial use? Do you charge for MPEG.LA
By createstock in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2015, 04:57
