You require separate versions of x86, x64.
In general, you can't mix and match x86, x64 in a single script. (There is an exception, mp_pipeline, that enables you to run mixed scripts such as x86 plugins and filters in a x64 avisynth host or vice versa. But it's more of a workaround)
The application you use will determine which avisynth version is initialized. e.g. if you open .avs with vdub2 x86, then avisynth x86 will run. If you open .avs with vdub2 x64, then avisynth x64 will run. If you use ffmpeg x64, it will initialize avisynth x64 to run the script, etc...
Not r1576 . That page should be updated or deleted
The last one is the "official" and newest . It's a packaged version or r2915 MT
Results 31 to 31 of 31
Query about identifying field-blending
By pooksahib in forum Video ConversionReplies: 15Last Post: 19th Oct 2020, 01:59 -
How to fix this blending/ghosting.
By BÌG•bµdd in forum RestorationReplies: 3Last Post: 20th Apr 2017, 12:03 -
Aspect ratios and frame blending
By DaneClark in forum DVD & Blu-ray PlayersReplies: 5Last Post: 7th Jan 2017, 18:46 -
How to fix this blending?
By BÌG•bµdd in forum RestorationReplies: 9Last Post: 19th Jul 2015, 16:14 -
De-interlacing and de-blending help please
By hello_hello in forum Video ConversionReplies: 3Last Post: 10th Feb 2015, 07:31
