I have a WINTV GO capture card in an old P2 350MHZ 512SDRAM Win98 computer that came with a bundle of software that included WINTV2000 program that I've heard is really good.
Does anybody know if that program will work with my new AVERTV PVR in a P4 1.6ghz 512RDR WinXP?
Also should I switch capture cards?
First thing you need to do is check if the software is XP/2000/NT compatible. If it's not, there's a quick answer.
Stan
Cant get either video capture card to work
By ralphey in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 21:02 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00 -
Would an older capture card work on a Vista PC?
By Rein Engel in forum Capturing and VCRReplies: 15Last Post: 23rd Jun 2007, 12:33 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
