Hello everyone,
I am new to the world of video creation / authoring and as the topic title already says, I need some help.
What I want to do:
burn a CD-ROM, that contains multiple data sources:
- a video (in a format, that plays on most DVD players)
- an mp3 (that plays on CD-players with mp3 support)
What I have got:
- MP4 (854x480, AVC, Main@L3.1, 29.97, 2h 13min, 404MB)
- MP3 (CBR 128, 2h 13min, 130MB)
What I have done so far:
- tried some of the proposed software here Authoring (SVCD/VCD) Free Downloads - VideoHelp
- searched the web for software and tried many of them
Unfortunately none of what I have tried did what I wanted it to.
Any help appreciated
you're not going to get 133 minutes of video onto a cd in any format that will have enough bitrate to be watchable on a tv. svcd is good up to about 45 minutes. vcd twice that, but is cbr and can only hold 80 minutes of video tops. and finding players that support vcd, and svcd may be hard.
did you try just writing the mp4 and mp3 to a cd as files? some players may accept them.
a dvd may work better, that way you could at least make a higher quality video.--
848x480 isn't a valid size for DVD playback, you'll have to resize to one of the sizes listed in the following link by cropping top, bottom or both or resizing it and adding a border top and or sides :https://www.videohelp.com/dvd
You add your .mp3 (and any other file) to the Extras folder on a DVD, but not all DVD players will be able access and play the file
You can add the audio to the Audio video on a DVD, but you'll have to convert it to one of the valid audio formats listed in the link above. Not all DVD players will be able to access and play the file since the Audio folder is rarely used.
It may be possible to make a mini-DVD on a CD with the DVD file structure, but the video would have to resized to fit 320x240 at MPEG-1 and be a really low bitrate to get 133 minutes, possibly below the minimum bitrate allowed by the DVD specs -
Yeah, you are gonna have to make a decision between using older, authored formats (look up my old posts on AVCD) for more universal legacy compatibility
vs
Using newer tech (bd) or Using data discs to retain quality along with full playing time.
ScottLast edited by Cornucopia; 23rd Dec 2019 at 12:36.
Actually I want to copy a video for my mum. She only has a DVD player / TV and an old PC with a 19" 4:3 monitor.
So the only way she can watch movies in "higher" resolutions is via DVD player.
I have multiple source files
The first is an mp4 A/V file:
The second source is seperate A/V as HD-ready video + 160 kbps mp3:Code:General Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/mp42) File size : 434 MiB Duration : 2 h 13 min Overall bit rate mode : Variable Overall bit rate : 455 kb/s Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3 Format settings : 1 Ref Frames Format settings, CABAC : No Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=60 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2 h 13 min Bit rate : 356 kb/s Maximum bit rate : 1 336 kb/s Width : 640 pixels Height : 360 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.052 Stream size : 340 MiB (78%) Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 2 h 13 min Bit rate mode : Variable Bit rate : 96.0 kb/s Maximum bit rate : 102 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 91.6 MiB (21%)
Toshiba SD3010KECode:General Format : dash Codec ID : dash (iso6/avc1/mp41) File size : 785 MiB Duration : 2 h 13 min Overall bit rate : 823 kb/s Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2 h 13 min Bit rate : 820 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.030 Stream size : 783 MiB (100%) Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC
- DVD Video disc
- DVD+R/RW
- DVD+R DL
DVD Video format or Audio/Video formats (e.g., MP3, JPEG and DivXfiles). - CD-R
Audio/Video formats (e.g., MP3,®JPEG and DivX files) - CD-RW (CD-Rewritable
Audio/Video formats (e.g., MP3,®JPEG and DivX files) - Audio CD
- Video CD (Formats 1.0, 1.1, 2.0)
- Super Video CD
- MP3-Disc
What would be the best solution?DivX®- The file extensions have to be '.DIVX', '.XVID' or '.AVI'.
- DivX3.11, 4.x, 5.x and 6.0.
The best you could do with that would either be creating a DVD data disc that had DivX (or Xvid masquerading) files & mp3 files.
Or,
A standard DVD-Video disc.
The former has the potential for higher resolution, but the toolset & process might be cumbersome trying to find what actually works.
The latter has straightforward tools and techniques and is universally supported, but can give SD video at best.
However, it doesn't sound like that tv is anything beyond a CRT and it sounds like it is being fed via composite cable, so the DVD path is preferrable.
ScottLast edited by Cornucopia; 28th Dec 2019 at 13:02.
AVIDemux can convert to xvid, chose MPEG4 ASP (xvid4) as the video output. The audio as .mp3 in the second file should be fine. I'm not sure the odd resolutions 854x480 and 640x360 or the 720p since the player is primarily DVD.
Edit: Just dawned on me. 854x480 is square pixel and 640x360 must be cropped 640x480, so not that odd.
No Luck Muxing a MP4 with a MP3, all software fails, each plays in VLC
By TBoneit in forum Video ConversionReplies: 12Last Post: 24th May 2019, 07:20 -
Merge audio file and image to create a video. Error: "track 1: muxing mp3..
By DennisO in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2018, 07:02 -
Create mp3 duplicates of all mp4-files in a folder using ffmpeg
By DennisO in forum Video ConversionReplies: 29Last Post: 23rd Nov 2018, 06:37 -
Can mp3 be converted so it plays on firefox?
By supercain in forum AudioReplies: 8Last Post: 7th Mar 2018, 20:45 -
Can a mono mp3 file be losslessly repackaged to joint stereo mp3?
By Condorcet in forum AudioReplies: 14Last Post: 9th Jul 2016, 09:46
