Hi
i know ,there are many trreads but many are updated
i don't own audio cd with 4 channels
a friend of mine bought a cd and there are 4 channels , it plays on it's car "stereo" and i can hear there are 4 different audio tracks
well i know the red book is 44100k @ 16bit
i tried to copy with anyburn without luck
i bought his cd and i can have a copy of it ,in europe
but are there some software that can do it ?
for example imgburn or CUETools or eac or EZ CD Audio Converter (the new easy cd extratotor ) or a RAW copy program?
or the only way to create a dvd audio cd (but i don't think his player read dvd )
thanks
ps i read somewhere there is possibile to copy cd 20 or 24bit and 48000 , at least some users were able to do it
Merry Xmas
Results 1 to 16 of 16
the only cd disc that can have 4 channels is an "sacd". they stopped producing them at least 10 years ago and could only play 4 ch. on a special sacd player. they have a second layer that contains normal cd audio that will play, but only in 2 ch. on a normal cd player. they are encrypted and aren't copy-able at all with normal equipment.
there is no way to read the 4 channel part of the sacd with a computer drive. long ago there were a couple people with hacked playstation 3s that had sacd drives that could read out that part, but that was the only way.
what's the top of the disc say? sacd or dvd? what color is the dye on the bottom?--
One other possibility is that it is a dts/dolbydigital-encoded quasi-cd. Aka dts or dd encoded multichannel, with zero padding interspersed to fill out to lpcm bitrates, encapsulated in and spoofing a standard wav file, so it can get authored as a standard cd even though it isn't.
Note that if you get/make one of these but don't have equipment that can auto recognize & decode properly, you will end up with high volume, stereo, digital noise. Which could possibly ruin your amp, your speakers, or your ears.
Scott -
The spec for redbook audio cd officially hinted that there would be a 4ch option, but in reality it never was created.
Sounds like your friend bought a commercial (pressed) disc, and if so will always be silver, and will not be a dts/dd cd but rather a dvd-video, or dvd-audio, (or universal), or sacd. Or possibly bluray (automotive players do exist).
Scott -
It's possible to copy, but the issue is can it be decrypted?
Scott -
hi
i don't know where has he bought it
there is an orginal cover (plastic) and dvd or cd looks legit
well i will try again with imgburn and the dvd , if it works well , if it doesn't work well he need to keep the original
but it's really weird that new hardware , blue ray , dvd can't copy such dvd or cd even are not standard like redbook
thanks Scott -
Dvd, sacd, and bluray ARE standard. However, they were DESIGNED to not be copyable.
And if the big companies had known that CDs would be copyable, they would have made them more difficult as well.
Scott -
Legally copyable is another matter.
I'm talking about technologically copyable. Cd is easy, as it needs no decryption (it has no encryption).
DVD is mildly difficult due to ccs.
Bd is quite difficult due to aacs & bd+. Uhdbd is even more difficult.
Sacd is near impossible due to psp watermarking & proprietary (& licensed) decryption algorithms & keys.
Legally, Europe is on stronger ground when it comes to fair use loopholes, but both your and my areas are signees of enforcement of the strict WIPO requirements.
Scott -
If you posted a picture of the disc you could have solved your dilemma in two posts.
Audio and video coming through on different AV channels on TV
By DRM32 in forum DVB / IPTVReplies: 5Last Post: 16th May 2017, 12:38 -
ffmpeg split audio channels
By Selur in forum Newbie / General discussionsReplies: 9Last Post: 27th Jan 2017, 17:14 -
Missing audio channels in Virtualdub
By tokintmash in forum Capturing and VCRReplies: 2Last Post: 7th Nov 2016, 09:20 -
Audio Channels and A/R
By Ex Machinas in forum AudioReplies: 16Last Post: 9th Dec 2015, 14:26 -
FFMPEG: can "select" audio channels using -acodec copy?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2015, 19:04
