GOAL:
Remove Audio from an existing Video Track and replace it with Externally recorded Audio (no disturbance from people who are sitting next to camcorder). This for a speech that was given at a Non-Profit.
When I put in the externally recorded Audio, it went out of sync with the video. So I figured out that it was because of VFR (Variable Frame Rate). I confirmed this by editing about 1 hour of video from 6 hours and overlaying the audio. I think this sample size is not enough.
Do I have to convert to a CFR of 60? Does this affect the audio bit rate (128)?
I am also looking for a website that can do this online (have about 9gb - 6 hours of video). But I think no website allows more than 1gb of data upload. So I used Handbrake to the sample conversion.
Would really appreciate any help that can save time and improve quality.
Win 10 Home
Inspiron 7737
Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz, 2001 Mhz, 2 Core(s), 4 Logical Processor(s)
RAM 8gb
Format : MPEG-PS
File size : 1.38 GiB
Duration : 46 min 22 s
Overall bit rate : 4 261 kb/s
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High 1440
Format settings : BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Bit rate mode : Variable
Bit rate : 3 952 kb/s
Maximum bit rate : 4 000 kb/s
Width : 1 440 pixels
Height : 808 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.113
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 1.28 GiB (93%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Bit rate mode : Constant
Bit rate : 224 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 38.281 FPS (1152 SPF)
Stream size : 74.3 MiB (5%)
Thx
That video is NOT vfr, it is cfr (29.97).
You are mistaking that with vbr. Bitrate. Has nothing to do with your sync issue, other than possible playback bottleneck on a really weak device.
Audio bitrate is independent from video bitrate. Note that your current mp2 audio is 224kbps, not 128. Don't go down to 128 unless you want it to sound crappier.
Since your vid is already cfr, going to 60 doesn't gain you anything, and also makes the bitrate's job harder.
Your sync issues are due to something else - maybe wrong interpretation settings in the editor...
Scott -
what camera was used? it's 30p mpeg-2 1440x808. not a normal size. and is that the original audio spec listed? mp2 at 44.1 khtz? 38.281fps? again unusual. most is 48 khtz.
@Cornucopia - Thx for those insights. I had mistaken VFR with VBR.
@aedipuss - It is a very old Camcorder. I guess that could be the sync issue source. Every time I had used HandBrake and edited in the audio it would sync perfectly. I guess it is time to buy a good camcorder - predominantly going to be used for indoors - speech recording.
I want to convert VFR to CFR while keeping the video interlaced
By ENunn in forum Video ConversionReplies: 34Last Post: 24th Apr 2019, 05:50 -
VFR TO CFR in avisynth 64bit and LSMASH source^?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2017, 07:28 -
Turning video from VFR to CFR without re-encoding?
By yetanotherlogin in forum EditingReplies: 3Last Post: 29th Aug 2016, 11:09 -
VFR to CFR
By SameSelf in forum Video ConversionReplies: 6Last Post: 7th Jun 2016, 20:46 -
RipBot264 and Handbrake producing VFR when CFR is selected
By duffbeer in forum Blu-ray RippingReplies: 9Last Post: 22nd Jan 2015, 09:50
