  1. Please advise/guide what command use defining/restricting Format Setting GOP M, N frames (pic attached) in FFmpeg & after encoding media info will show the GOP M, N frames.
Name:	GOP settings.JPG
  2. Member Cornucopia's Avatar
    Why are you asking this? What are you trying to achieve?
  3. For learning & to bit grip on FFmpeg commands. would you like to tell the command ?
  4. MediaInfo N and M, see for example here:
    https://en.wikipedia.org/wiki/Group_of_pictures
    ffmpeg supports many video codecs. How you set N and M (GOP structure) depends on the syntax of the selected codec. You have to dig into the codec's settings parameters for details.
  5. Member Cornucopia's Avatar
    Why you set those settings is determined by how you are trying to craft your stream to match your requirements, in terms of quality, bitrate/filesize, complexity, efficiency.
  6. Yes, Scott you're right. Please share command for setting those parameters for H.264 codec.
    Thanks.
