I just got some new VCDs and when I try to play the DAT on my Windows Media Player, it gives me an error message "A device attached to the system is not functioning." When I hit "Details" this is the explanation, even though I have no problems with any of my other DAT files:
Using Windows Media Player and Windows Media Services on the same computer
Error ID = 0x8007001F, Remedy ID = 0x00000000
This error happens if you use Microsoft Windows Media Services and Windows Media Player on the same computer and attempt to view a file in Windows Media Player that is streamed by the same server.
Windows Media Player must be installed on a different computer than Windows Media Services.
Try converting DAT file to mpeg file with VCDGear, which should be OK with WM Player. I don't know PowerDVD or WinDVD can play DAT files, but they should.
No audio playing M2TS files with Windows Media Player
By majouz in forum Software PlayingReplies: 6Last Post: 24th Jan 2013, 05:47 -
Crop videos playing on Windows Media Player
By kingshay in forum Software PlayingReplies: 2Last Post: 28th Nov 2010, 13:00 -
Windows Media Player stopped playing .mov files
By dzsoul in forum Software PlayingReplies: 2Last Post: 19th Mar 2009, 00:29 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
Revised Question: Problem playing joined file on windows media player
By Johnny_Blaze in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 13:25
