I've got batch script to merge MP4 files and separate subtitles files into MKVs. When I run the script it asks me to enter the language. The problem with MKVMerge is that as soon as you set the language all your other settings such as setting default subs to off are ignored. What part of the script do I need to remove to prevent it asking me for a language? I tried removing the part I thought it was myself but when I run the script and get to that part the script just closes itself without doing anything.
Code:@echo off echo ---------------------------------------------------------------------- echo VIDEO AND SUBTITLE MERGER echo version 1.0.0 by Seyoum echo ---------------------------------------------------------------------- :: Set file video extention :VIDEOFILEEXTENTION echo. set /p videofileformat=Enter the video file type extension (e.g mp4): if /I "%videofileformat%" EQU "webm" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mkv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "flv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "flv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "vob" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "ogv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "ogg" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "drc" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "gif" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "gifv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mng" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "avi" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mov" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "qt" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "wmv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "yuv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "rm" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "rmvb" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "asf" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mp4" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "m4p" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "m4v" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mpg" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mp2" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mpeg" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mpe" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mpv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mpg" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mpeg" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "m2v" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "m4v" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "svi" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "3gp" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "3g2" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "mxf" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "roq" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "nsv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "flv" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "f4v" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "f4p" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "f4a" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION if /I "%videofileformat%" EQU "f4b" echo You have chosen %videofileformat% as your video file format&goto:SUBTITLEFILEEXTENTION echo you have entered something invalid&goto:VIDEOFILEEXTENTION :: Set subtitle file extention :SUBTITLEFILEEXTENTION echo. set /p subtitlefileformat=Enter the subtitle file type extention(e.g srt): if /I "%subtitlefileformat%" EQU "aqt" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "gsub" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "txt" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "jss" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "sub" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "ttxt" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "pjs" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "psb" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "rt" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "smi" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "stl" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "ssf" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "srt" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "ssa" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "ass" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "usf" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "idx" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "usf" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage if /I "%subtitlefileformat%" EQU "pgs" echo You have chosen %subtitlefileformat% as your subtitle file format&goto:Get_ISOlanguage echo you have entered something invalid&goto:SUBTITLEFILEEXTENTION :: Set Subtitle language code :Get_ISOlanguage echo. set "language=not valid" set /p "ISOlanguage=Enter subtitle language(e.g eng, fre, ger or similar):" for /f "tokens=3 delims=," %%i in ('find "DATA,%ISOlanguage%," "%~f0"') do set language=%%i echo - You have chosen %language% subtitles if "%language%"=="not valid" goto :Get_ISOlanguage goto :CONTINUE1 DATA,abk,Abkhazian DATA,ace,Achinese DATA,ach,Acoli DATA,ada,Adangme DATA,ady,Adyghe; Adygei DATA,aar,Afar DATA,afh,Afrihili DATA,afr,Afrikaans DATA,afa,Afro-Asiatic languages DATA,ain,Ainu DATA,aka,Akan DATA,akk,Akkadian DATA,alb,Albanian DATA,ale,Aleut DATA,alg,Algonquian languages DATA,tut,Altaic languages DATA,amh,Amharic DATA,anp,Angika DATA,apa,Apache languages DATA,ara,Arabic DATA,arg,Aragonese DATA,arp,Arapaho DATA,arw,Arawak DATA,arm,Armenian DATA,rup,Aromanian; Arumanian; Macedo-Romanian DATA,art,Artificial languages DATA,asm,Assamese DATA,ast,Asturian; Bable; Leonese; Asturleonese DATA,ath,Athapascan languages DATA,aus,Australian languages DATA,map,Austronesian languages DATA,ava,Avaric DATA,ave,Avestan DATA,awa,Awadhi DATA,aym,Aymara DATA,aze,Azerbaijani DATA,ban,Balinese DATA,bat,Baltic languages DATA,bal,Baluchi DATA,bam,Bambara DATA,bai,Bamileke languages DATA,bad,Banda languages DATA,bnt,Bantu languages DATA,bas,Basa DATA,bak,Bashkir DATA,baq,Basque DATA,btk,Batak languages DATA,bej,Beja; Bedawiyet DATA,bel,Belarusian DATA,bem,Bemba DATA,ben,Bengali DATA,ber,Berber languages DATA,bho,Bhojpuri DATA,bih,Bihari languages DATA,bik,Bikol DATA,bin,Bini; Edo DATA,bis,Bislama DATA,byn,Blin; Bilin DATA,zbl,Blissymbols; Blissymbolics; Bliss DATA,nob,Bokmål, Norwegian; Norwegian Bokmål DATA,bos,Bosnian DATA,bra,Braj DATA,bre,Breton DATA,bug,Buginese DATA,bul,Bulgarian DATA,bua,Buriat DATA,bur,Burmese DATA,cad,Caddo DATA,cat,Catalan; Valencian DATA,cau,Caucasian languages DATA,ceb,Cebuano DATA,cel,Celtic languages DATA,cai,Central American Indian languages DATA,khm,Central Khmer DATA,chg,Chagatai DATA,cmc,Chamic languages DATA,cha,Chamorro DATA,che,Chechen DATA,chr,Cherokee DATA,chy,Cheyenne DATA,chb,Chibcha DATA,nya,Chichewa; Chewa; Nyanja DATA,chi,Chinese DATA,chp,Chipewyan; Dene Suline DATA,cho,Choctaw DATA,chu,Church Slavic; Old Slavonic; Church Slavonic; Old Bulgarian; Old Church Slavonic DATA,chk,Chuukese DATA,chv,Chuvash DATA,nwc,Classical Newari; Old Newari; Classical Nepal Bhasa DATA,syc,Classical Syriac DATA,cop,Coptic DATA,cor,Cornish DATA,cos,Corsican DATA,cre,Cree DATA,mus,Creek DATA,crp,Creoles and pidgins DATA,cpe,Creoles and pidgins, English based DATA,cpf,Creoles and pidgins, French-based DATA,cpp,Creoles and pidgins, Portuguese-based DATA,crh,Crimean Tatar; Crimean Turkish DATA,hrv,Croatian DATA,cus,Cushitic languages DATA,cze,Czech DATA,dak,Dakota DATA,dan,Danish DATA,dar,Dargwa DATA,del,Delaware DATA,din,Dinka DATA,div,Divehi; Dhivehi; Maldivian DATA,doi,Dogri DATA,dgr,Dogrib DATA,dra,Dravidian languages DATA,dua,Duala DATA,dum,Dutch, Middle (ca.1050-1350) DATA,dut,Dutch; Flemish DATA,dyu,Dyula DATA,dzo,Dzongkha DATA,frs,Eastern Frisian DATA,efi,Efik DATA,egy,Egyptian (Ancient) DATA,eka,Ekajuk DATA,elx,Elamite DATA,eng,English DATA,myv,Erzya DATA,epo,Esperanto DATA,est,Estonian DATA,ewe,Ewe DATA,ewo,Ewondo DATA,fan,Fang DATA,fat,Fanti DATA,fao,Faroese DATA,fij,Fijian DATA,fil,Filipino; Pilipino DATA,fin,Finnish DATA,fiu,Finno-Ugrian languages DATA,fon,Fon DATA,fre,French DATA,frm,French, Middle (ca.1400-1600) DATA,fro,French, Old (842-ca.1400) DATA,fur,Friulian DATA,ful,Fulah DATA,gaa,Ga DATA,gla,Gaelic; Scottish Gaelic DATA,car,Galibi Carib DATA,glg,Galician DATA,lug,Ganda DATA,gay,Gayo DATA,gba,Gbaya DATA,gez,Geez DATA,geo,Georgian DATA,ger,German DATA,gil,Gilbertese DATA,gon,Gondi DATA,gor,Gorontalo DATA,got,Gothic DATA,grb,Grebo DATA,grc,Greek, Ancient (to 1453) DATA,gre,Greek, Modern (1453-) DATA,grn,Guarani DATA,guj,Gujarati DATA,gwi,Gwich'in DATA,hai,Haida DATA,hat,Haitian; Haitian Creole DATA,hau,Hausa DATA,haw,Hawaiian DATA,heb,Hebrew DATA,her,Herero DATA,hil,Hiligaynon DATA,him,Himachali languages; Western Pahari languages DATA,hin,Hindi DATA,hmo,Hiri Motu DATA,hit,Hittite DATA,hmn,Hmong; Mong DATA,hun,Hungarian DATA,hup,Hupa DATA,iba,Iban DATA,ice,Icelandic DATA,ido,Ido DATA,ibo,Igbo DATA,ijo,Ijo languages DATA,ilo,Iloko DATA,smn,Inari Sami DATA,inc,Indic languages DATA,ine,Indo-European languages DATA,ind,Indonesian DATA,inh,Ingush DATA,ina,Interlingua (International Auxiliary Language Association) DATA,ile,Interlingue; Occidental DATA,iku,Inuktitut DATA,ipk,Inupiaq DATA,ira,Iranian languages DATA,gle,Irish DATA,mga,Irish, Middle (900-1200) DATA,sga,Irish, Old (to 900) DATA,iro,Iroquoian languages DATA,ita,Italian DATA,jpn,Japanese DATA,jav,Javanese DATA,jrb,Judeo-Arabic DATA,jpr,Judeo-Persian DATA,kbd,Kabardian DATA,kab,Kabyle DATA,kac,Kachin; Jingpho DATA,kal,Kalaallisut; Greenlandic DATA,xal,Kalmyk; Oirat DATA,kam,Kamba DATA,kan,Kannada DATA,kau,Kanuri DATA,krc,Karachay-Balkar DATA,kaa,Kara-Kalpak DATA,krl,Karelian DATA,kar,Karen languages DATA,kas,Kashmiri DATA,csb,Kashubian DATA,kaw,Kawi DATA,kaz,Kazakh DATA,kha,Khasi DATA,khi,Khoisan languages DATA,kho,Khotanese; Sakan DATA,kik,Kikuyu; Gikuyu DATA,kmb,Kimbundu DATA,kin,Kinyarwanda DATA,kir,Kirghiz; Kyrgyz DATA,tlh,Klingon; tlhIngan-Hol DATA,kom,Komi DATA,kon,Kongo DATA,kok,Konkani DATA,kor,Korean DATA,kos,Kosraean DATA,kpe,Kpelle DATA,kro,Kru languages DATA,kua,Kuanyama; Kwanyama DATA,kum,Kumyk DATA,kur,Kurdish DATA,kru,Kurukh DATA,kut,Kutenai DATA,lad,Ladino DATA,lah,Lahnda DATA,lam,Lamba DATA,day,Land Dayak languages DATA,lao,Lao DATA,lat,Latin DATA,lav,Latvian DATA,lez,Lezghian DATA,lim,Limburgan; Limburger; Limburgish DATA,lin,Lingala DATA,lit,Lithuanian DATA,jbo,Lojban DATA,nds,Low German; Low Saxon; German, Low; Saxon, Low DATA,dsb,Lower Sorbian DATA,loz,Lozi DATA,lub,Luba-Katanga DATA,lua,Luba-Lulua DATA,lui,Luiseno DATA,smj,Lule Sami DATA,lun,Lunda DATA,luo,Luo (Kenya and Tanzania) DATA,lus,Lushai DATA,ltz,Luxembourgish; Letzeburgesch DATA,mac,Macedonian DATA,mad,Madurese DATA,mag,Magahi DATA,mai,Maithili DATA,mak,Makasar DATA,mlg,Malagasy DATA,may,Malay DATA,mal,Malayalam DATA,mlt,Maltese DATA,mnc,Manchu DATA,mdr,Mandar DATA,man,Mandingo DATA,mni,Manipuri DATA,mno,Manobo languages DATA,glv,Manx DATA,mao,Maori DATA,arn,Mapudungun; Mapuche DATA,mar,Marathi DATA,chm,Mari DATA,mah,Marshallese DATA,mwr,Marwari DATA,mas,Masai DATA,myn,Mayan languages DATA,men,Mende DATA,mic,Mi'kmaq; Micmac DATA,min,Minangkabau DATA,mwl,Mirandese DATA,moh,Mohawk DATA,mdf,Moksha DATA,lol,Mongo DATA,mon,Mongolian DATA,mkh,Mon-Khmer languages DATA,mos,Mossi DATA,mul,Multiple languages DATA,mun,Munda languages DATA,nah,Nahuatl languages DATA,nau,Nauru DATA,nav,Navajo; Navaho DATA,nde,Ndebele, North; North Ndebele DATA,nbl,Ndebele, South; South Ndebele DATA,ndo,Ndonga DATA,nap,Neapolitan DATA,new,Nepal Bhasa; Newari DATA,nep,Nepali DATA,nia,Nias DATA,nic,Niger-Kordofanian languages DATA,ssa,Nilo-Saharan languages DATA,niu,Niuean DATA,nqo,N'Ko DATA,zxx,No linguistic content; Not applicable DATA,nog,Nogai DATA,non,Norse, Old DATA,nai,North American Indian languages DATA,frr,Northern Frisian DATA,sme,Northern Sami DATA,nor,Norwegian DATA,nno,Norwegian Nynorsk; Nynorsk, Norwegian DATA,nub,Nubian languages DATA,nym,Nyamwezi DATA,nyn,Nyankole DATA,nyo,Nyoro DATA,nzi,Nzima DATA,oci,Occitan (post 1500) DATA,arc,Official Aramaic (700-300 BCE); Imperial Aramaic (700-300 BCE) DATA,oji,Ojibwa DATA,ori,Oriya DATA,orm,Oromo DATA,osa,Osage DATA,oss,Ossetian; Ossetic DATA,oto,Otomian languages DATA,pal,Pahlavi DATA,pau,Palauan DATA,pli,Pali DATA,pam,Pampanga; Kapampangan DATA,pag,Pangasinan DATA,pan,Panjabi; Punjabi DATA,pap,Papiamento DATA,paa,Papuan languages DATA,nso,Pedi; Sepedi; Northern Sotho DATA,per,Persian DATA,peo,Persian, Old (ca.600-400 B.C.) DATA,phi,Philippine languages DATA,phn,Phoenician DATA,pon,Pohnpeian DATA,pol,Polish DATA,por,Portuguese DATA,pra,Prakrit languages DATA,pro,Provençal, Old (to 1500);Occitan, Old (to 1500) DATA,pus,Pushto; Pashto DATA,que,Quechua DATA,raj,Rajasthani DATA,rap,Rapanui DATA,rar,Rarotongan; Cook Islands Maori DATA,qaa,Reserved for local use DATA,roa,Romance languages DATA,rum,Romanian; Moldavian; Moldovan DATA,roh,Romansh DATA,rom,Romany DATA,run,Rundi DATA,rus,Russian DATA,sal,Salishan languages DATA,sam,Samaritan Aramaic DATA,smi,Sami languages DATA,smo,Samoan DATA,sad,Sandawe DATA,sag,Sango DATA,san,Sanskrit DATA,sat,Santali DATA,srd,Sardinian DATA,sas,Sasak DATA,sco,Scots DATA,sel,Selkup DATA,sem,Semitic languages DATA,srp,Serbian DATA,srr,Serer DATA,shn,Shan DATA,sna,Shona DATA,iii,Sichuan Yi; Nuosu DATA,scn,Sicilian DATA,sid,Sidamo DATA,sgn,Sign Languages DATA,bla,Siksika DATA,snd,Sindhi DATA,sin,Sinhala; Sinhalese DATA,sit,Sino-Tibetan languages DATA,sio,Siouan languages DATA,sms,Skolt Sami DATA,den,Slave (Athapascan) DATA,sla,Slavic languages DATA,slo,Slovak DATA,slv,Slovenian DATA,sog,Sogdian DATA,som,Somali DATA,son,Songhai languages DATA,snk,Soninke DATA,wen,Sorbian languages DATA,sot,Sotho, Southern DATA,sai,South American Indian languages DATA,alt,Southern Altai DATA,sma,Southern Sami DATA,spa,Spanish; Castilian DATA,srn,Sranan Tongo DATA,zgh,Standard Moroccan Tamazight DATA,suk,Sukuma DATA,sux,Sumerian DATA,sun,Sundanese DATA,sus,Susu DATA,swa,Swahili DATA,ssw,Swati DATA,swe,Swedish DATA,gsw,Swiss German; Alemannic; Alsatian DATA,syr,Syriac DATA,tgl,Tagalog DATA,tah,Tahitian DATA,tai,Tai languages DATA,tgk,Tajik DATA,tmh,Tamashek DATA,tam,Tamil DATA,tat,Tatar DATA,tel,Telugu DATA,ter,Tereno DATA,tet,Tetum DATA,tha,Thai DATA,tib,Tibetan DATA,tig,Tigre DATA,tir,Tigrinya DATA,tem,Timne DATA,tiv,Tiv DATA,tli,Tlingit DATA,tpi,Tok Pisin DATA,tkl,Tokelau DATA,tog,Tonga (Nyasa) DATA,ton,Tonga (Tonga Islands) DATA,tsi,Tsimshian DATA,tso,Tsonga DATA,tsn,Tswana DATA,tum,Tumbuka DATA,tup,Tupi languages DATA,tur,Turkish DATA,ota,Turkish, Ottoman (1500-1928) DATA,tuk,Turkmen DATA,tvl,Tuvalu DATA,tyv,Tuvinian DATA,twi,Twi DATA,udm,Udmurt DATA,uga,Ugaritic DATA,uig,Uighur; Uyghur DATA,ukr,Ukrainian DATA,umb,Umbundu DATA,mis,Uncoded languages DATA,und,Undetermined DATA,hsb,Upper Sorbian DATA,urd,Urdu DATA,uzb,Uzbek DATA,vai,Vai DATA,ven,Venda DATA,vie,Vietnamese DATA,vol,Volapük DATA,vot,Votic DATA,wak,Wakashan languages DATA,wln,Walloon DATA,war,Waray DATA,was,Washo DATA,wel,Welsh DATA,fry,Western Frisian DATA,wal,Wolaitta; Wolaytta DATA,wol,Wolof DATA,xho,Xhosa DATA,sah,Yakut DATA,yao,Yao DATA,yap,Yapese DATA,yid,Yiddish DATA,yor,Yoruba DATA,ypk,Yupik languages DATA,znd,Zande languages DATA,zap,Zapotec DATA,zza,Zaza; Dimili; Dimli; Kirdki; Kirmanjki; Zazaki DATA,zen,Zenaga DATA,zha,Zhuang; Chuang DATA,zul,Zulu DATA,zun,Zuni :CONTINUE1 :: Default yes/not :SubtitleDefaultYesNo echo. set /p subtitledefault=Do you want to make subtitles default [y/n]? : if /I "%subtitledefault%" EQU "y" set subtitledefault=0:yes&goto:CONTINUE2 if /I "%subtitledefault%" EQU "n" set subtitledefault=1:yes&goto:CONTINUE2 echo you have entered something invalid&goto:SubtitleDefaultYesNo :: Forced yes/not :CONTINUE2 :SubtitleForcedYesNo echo. set /p subtitledefault=Do you want to make subtitles forced [y/n]? : if /I "%subtitledefault%" EQU "y" set subtitledefault=0:yes&goto:CONTINUE3 if /I "%subtitledefault%" EQU "n" set subtitledefault=1:yes&goto:CONTINUE3 echo you have entered something invalid&goto:SubtitleForcedYesNo :: Set mkvmergepath :CONTINUE3 Setlocal EnableDelayedExpansion echo. set /p mkvmergepath=Enter the full path to mkvmerge (e.g C:\mkvtoolnix\mkvmerge.exe): if not exist "%mkvmergepath%" echo The path you have entered does not exist...&goto:CONTINUE3 ::Muxing operation echo. for %%A IN (*.%videofileformat%) do ( "!mkvmergepath!" -o "%%~nA.mkv" "%%~A" --forced-track "%subtitledefault%" --default-track "%subtitledefault%" --track-name "0:%language% subtitles" --language "0:%ISOlanguage%" "%%~nA.%subtitlefileformat%") :: Confirmation dialog @echo off echo ---------------------------------------------------------------------- echo Finished operation! echo Press any key to exit pause > nul cls
Results 1 to 1 of 1
MKVmerge Batch File - Remove Language
By cine24h in forum Newbie / General discussionsReplies: 11Last Post: 24th Jul 2019, 13:18 -
Batch convert ts to mkv with audio language tagging
By Learning2do in forum Newbie / General discussionsReplies: 3Last Post: 23rd Mar 2019, 04:53 -
Batch Script for Youtube-dl
By syalazar in forum Video Streaming DownloadingReplies: 1Last Post: 5th Feb 2019, 10:10 -
Need help with TS Muxer Batch Script
By VideoFanatic in forum Video ConversionReplies: 31Last Post: 29th Sep 2015, 18:40 -
Avidemux Batch Script
By Haukeluet in forum Video ConversionReplies: 8Last Post: 13th Feb 2015, 15:28
