it seems very hard obtain valid string from this link:
Code:https://xomphimhay.com/xem-phim/doan-thu-coc/388383/
Results 1 to 25 of 25
I got this link by pressing F12 right after pressing the start button (I have FireFox set to not play videos automatically):
https://download1.share-url.com/download?data=4e3j5eWllKjroKKfmNjnptCq39fX597bo9WZyejc...Com-Video-360p -
dear jagabo today server are changed, also IDM found video stream.
and yes confirmed new link of therain:
have 2 different server and from these 2 it's really hard to get a valid string....Code:https://xomphimhay.com/xem-phim/thuong-hai-tranh-hung/986846
lomero-In the future please use a better thread description rather than 'a hard option,choice etc...'for this time i changed your thread title.
LZZA it is useless to place here the only link to the file ....
what we are interested in is how to obtain or what it is, a valid string...Last edited by lomero; 25th Dec 2019 at 03:10.
i don't get any m3u8....
how to?Last edited by lomero; 25th Dec 2019 at 03:55.
Thanks you, it worked for me .Originally Posted by ;2568362
Used streamlink (not get the full streamlink command line with "The Stream Detector" plugin)
Hi lomero, please see attached for more detailsCode:[cli][info] Found matching plugin hls for URL https://ch9ly8ejx.william-crocker. xyz/hcOtSiTdVx2bEaAxLqOpLqCK7aI/playlist.m3u8 [cli][info] Available streams: 360p (worst, best) [cli][info] Opening stream: 360p (hls) [download][test02.ts] Written 6.7 MB (9s @ 637.1 KB/s) [ cli][info] Stream ended Interrupted! Exiting... [cli][info] Closing currently open stream...
Same the site it seems very hard obtain valid string to download with youtube-dl or streamlink
Video url --> https://www.bilibili.com/bangumi/play/ep131916
I'm tried every android,iphone and windows phone and i don't get any m3u8 or hls url
Is there any way to download content from this site (the high quality video with .flv format because the .mp4 is low quality), could someone kindly suggests a solution ?
Thanks for your help. -
... the high quality video with .flv format because the .mp4 is low quality
The quality is almost the same, but flv is easier to download.
Try IDM, but Tubedigger is more convenient
https://cloud.mail.ru/public/3aVG/4eRJcxV6FLast edited by sysanin; 26th Dec 2019 at 20:21.
annie can also be used on the command line for bilibili, though for 720/1080 qualities you'll need newer appkey= and corresponding sign= values.
Code:for all items in playlist; annie -p https://www.bilibili.com/bangumi/play/ep131916 to select items; annie -p -items 2 https://www.bilibili.com/bangumi/play/ep131916 (replace "2" will other "items" value as needed)
thanks both pro, it's worked .
That easy for annie (put ffmpeg same folder)
I try with code (annie -f 80 for 1080p) and get the .flv file with info belowStreams: # All available quality
[64] -------------------
Quality: ?? 720P
Size: 220.86 MiB (231588857 Bytes)
# download with: annie -f 64 ...
[32] -------------------
Quality: ?? 480P
# download with: annie -f 32 ...
[80] -------------------
Quality: ?? 1080P
Size: 220.86 MiB (231583355 Bytes)
# download with: annie -f 80 ...
[16] -------------------
Quality: ?? 360P
Size: 128.92 MiB (135183070 Bytes)
# download with: annie -f 16 ...
D:\Capture TV\annie_0.9.6_Windows_64-bit>annie -f 80 https://www.bilibili.com/ba
ngumi/play/ep131916
Site: ???? bilibili.com
Title: ?????
1?
Type: video
Stream:
Quality: ?? 1080P
220.86 MiB / 220.86 MiB [========================] 100.00% 194.81 KiB/s 19m20s
How to (appkey= and corresponding sign= values) for download video 1080 quality, please help me for example .Format : Flash Video
File size : 221 MiB
Duration : 47mn 45s
Overall bit rate : 647 Kbps
Tagging application : Yet Another Metadata Injector for FLV - Version 1.8
Video
Format : AVC
Format profile : Main@L3
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : 7
Duration : 47mn 45s
Bit rate : 500 Kbps
Width : 720 pixels
Height : 532 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.052
Stream size : 175 MiB (79%)
Thanks so much !Last edited by therain; 27th Dec 2019 at 08:14.
all -f (80-64-32) have same resolution (720x532)
only -f 16 is lower...
indeed you just need to see the size format same for all 3 format (Size: 220.86 MiB (231583355 Bytes) -
Thanks lomero, it's ok for this link .
For example from link --> https://www.bilibili.com/video/av34507530?p=1
Try view page source i get (noted : hdflv2 = 1080P+ = 112)
Used annie to get the high quality video 1080P and 1080P+ not available"hdflv2,flv,flv720,flv480,flv360","accept_description":["高清 1080P+","高清 1080P","高清 720P","清晰 480P","流畅 360P"],"accept_quality":[112,80,64,32,16]
For youtube-dl i get 1080P with this link belowD:\Capture TV\annie_0.9.6_Windows_64-bit>annie -i https://www.bilibili.com/video
/av34507530?p=1
Title: ??????????? ?43??2007? P1 01
Type: video
Quality: ?? 1080P
Size: 1049.43 MiB (1100408867 Bytes)
Quality: ?? 720P
Size: 712.92 MiB (747552335 Bytes)
Quality: ?? 480P
Size: 359.70 MiB (377173834 Bytes)
Quality: ?? 360P
Size: 155.11 MiB (162644330 Bytes)
then replaced on this string 60300614/60300614-1-80.flv to 60300614/60300614-1-112.flv but does not workCode:http://upos-hz-mirrorakam.akamaized.net/upgcxcode/14/06/60300614/60300614-1-80.flv?e=ig8euxZM2rNcNbRVhbNBhwdlhWdghbUVhoNvNC8BqJIzNbfqXBvEqxTEto8BTrNvN0GvT90W5JZMkX_YN0MvXg8gNEVEuxTEto8i8o859r1qXg8xNEVE5XREto8GuFGv2U7SuxI72X6fTr859r1qXg8gNEVE5XREto8z5JZC2X2gkX5L5F1eTX1jkXlsTXHeux_f2o859IB_&deadline=1577466538&dynamic=1&gen=playurl&oi=20264954&os=akam&platform=pc&rate=1022500&trid=a4b364ac5f7c423097179093225a68c9&uipk=5&uipv=5&um_deadline=1577466538&um_sign=8dded46fdce0428d11ec93f8b1bfacd9&upsig=8cad9ff3e233438362a16306e6207f73&uparams=e,deadline,dynamic,gen,oi,os,platform,rate,trid,uipk,uipv,um_deadline,um_sign&hdnts=exp=1577466538~hmac=28f844e340662efe2800e85233a4d060212bb44411eded71f1921d6134c0e41f&mid=0
So, how to (appkey= and corresponding sign= values) for download video 1080P+ quality, please help me for example .
Thanks so much !Last edited by therain; 27th Dec 2019 at 10:14.
youtube Download
By cornemuse in forum AudioReplies: 4Last Post: 3rd Sep 2019, 22:51 -
How to download .m3u8 video with query string and EXT-X-KEY?
By j3321202 in forum Video Streaming DownloadingReplies: 23Last Post: 19th Jun 2019, 14:49 -
How to download this video clip? Link valid until tomorrow
By rogue2020 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Sep 2016, 11:26 -
Inability to download Youtube video by Youtube Downloader HD
By jgp123 in forum Video Streaming DownloadingReplies: 9Last Post: 17th Nov 2015, 06:03 -
How to obtain the download? RMTPDUMP, FFMPEG, LIVESTREAM??!
By okimista in forum Video Streaming DownloadingReplies: 7Last Post: 21st Apr 2015, 10:27
