  1. Swollen Member
    Mar 2002
    Kanuckistan
    I ripped a DVD just to see if it would work, with Smartripper. Setting was with Macrovision off and Region free. (Used the Backup Disc function on a single-layer disc.)
    I set Nero to burn as UDF/ISO DVD-ROM ISO Level 2 ISO 9660 (Relax restrictions UNchecked).
    The final disc works fine in my PC (both the DVD-R and DVD-ROM drives), and my Apex, but not in my Panasonic DVD player nor my Mac.
    Can Smartripper's Macrovision and Region free settings screw things up?
    Or should I just Nero's UDF setting instead of UDF/ISO? Are there any special UDF setting parameters that need to be set?
    Or should I just use neoDVD's copy disc function (on my ripped files) to make a DVD?
    DVD-ROM is Pioneer 104F
    DVD-R is Panasonic LF-D311
  2. Swollen Member
    Mar 2002
    Kanuckistan
    P.S. Two other points:
    1) My "video_ts" directory was in lower case
    2) There was no "audio_ts" directory
    Could either of these cause the problems?
  3. I used Smartripper with de-Macro and de-Region, dragged all files into Nero's DVD-Video template's VIDEO_TS folder. Burned, worked perfect. Try using the DVD-Video option in the latest version of Nero. That should give you better compatibility.
    May 2001
    For the highest compatibility, always use the old DOS 8.3 (FILENAME.EXT) naming conventions, and always use capital letters in directory and file names.
  5. Hi,nice info,i jus ripped a move in the exact same way,i went 2 dvd video in nero 5582
    and dragged all my ripped files in 2 the video_ts folder,so i had 1 video_ts foler with all the ripped file incl vob,bup,ifo
    But after i burned it,it wudnt play in my player??
    Im a first time at this,so i jus need 2 know what r the best setting 2 use,i chked the meduim info on the original dvd and it sed udfiso9660
    Plz sum help me out,i want 2 make a pure copy of the film,incl menu ,featues etc..
    but i jus need the correct settings
    Tanx a lot
    Spida!
    May 2001
    Make sure that you use FILES in Smartripper to get ALL the files (in MOVIE, you don't get everything that you need). Drag THESE files to NERO. This should give you success.
    Check the number of files in the VIDEO_TS directory on your burned disk... the check the number on the original. Let us know if they are the same.
  7. Also make sure that the media you are using isn't crap. If you are using the $2.00 DVD-R's that could be your problem. Stick with the Apple disks or the Pioneer and you won't have any problems........
