Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
    Dec 2019
    Coevorden, Netherlands
    won't see much difference between the original VOB and an AVC MP4 file at 1/2, maybe even 1/4 the size.
    I assume jagabo was referring to file size rather than resolution.
    I was also referring to file size, won't the quality difference between the file sizes be more visible when viewed on large resolutions?
    As in: "the quality is worse, only if you zoom in it will be visible to you"
  2. If you don't want to loose video quality
    If you dont want to increase the size of your copy
    if you want to do fast DVD copy
    Then your solution is XviD4PSP or XMedia Recode: import your DVD slect copy video select the container you prefer and then select the audio and subtitles you need
    No faster and better solution
    Dec 2019
    But I need to crop and cut too. A larger file size (I mean larger than the original) is no problem as long as the larger size is usefull in a noticable quality matter
  4. Originally Posted by MwBakker View Post
    It depends on your viewing distance. A 20 inch monitor from 2 feet away looks the same as a 60 inch TV from 6 feet away (all else being equal, of course).
    Dec 2019
    heh I mean reasonable distance of course
  6. For no other reason than to save myself from looking foolish, I've replaced the 640x480 encode in my previous post with a new version, because I realised I did a silly that stretched the picture a little. Probably not enough to notice unless you compared the two encodes directly, but I'm a bit OCD about that sort of thing.
    Dec 2019
    So am I, especially since it's always about memories which can never be recreated
    May 2020
    Hi there i converted my dvd's data to the files and i'm facing extensions problems. Can anyone help me throughout this scenario... whereaminow
    Probably.
    Details would help.
