I'm using the Roxio Easy VHS to DVD 3 Plus and getting yellow lines in the captured video. These are not visible when playing directly from the VCR to the TV. Is there any way I can correct this using software or hardware? If so, what can I use?
[Attachment 51154 - Click to enlarge]
you probably can adjust that with virtualdub filters:
1- camcorder color denoise
2- gradation curves (in CMYK mode)
3- color mill
if you can upload a video sample i'll tell you more*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
There's so little color in that clip you might as well just reduce it to greyscale.
Anyone know of a sub program that will break long lines into 3 lines?
By JeremyBrown in forum SubtitleReplies: 19Last Post: 13th Apr 2020, 19:03 -
Hot to move lines to next lines time?
By tevastevas in forum SubtitleReplies: 1Last Post: 23rd Aug 2019, 02:34 -
Freemake Video Converter unwanted yellow logos
By CVK in forum Newbie / General discussionsReplies: 5Last Post: 20th Apr 2018, 17:01 -
Lines on video during capturing and on captured video.
By nusratjaveid in forum Capturing and VCRReplies: 6Last Post: 17th Mar 2016, 14:13 -
DVDR with Lines on Top and Lines on Bottom?
By Disco Makberto in forum MediaReplies: 13Last Post: 14th Feb 2015, 03:34
