I just got three 12TB WD external drives, decased them and completed 9TB of file transfers from the original two other drives (same data, one a backup), to two of them. Happily formatted the old 4TB drive to use in another PC, but when I checked it, it was still full! Yep! Formatted the 12TB drive!
Just a little panic as I realized, I still had the three of the four original drives intact (already formatted and starting copying files to the fourth), plus I had a completed copy job on the other 12TB.
I've restarted copying files from the two original drives to the new one, which is a good thing since it's a mini-stress test to run the drives for nearly 48 hours straight by the time it's done copying and verifying.
I'm starting a copy of the files from the second 12TB to the third, so I have a backup of the backup without having to start from scratch in the event of failure. No, I don't keep the backup drive offset (though I should), but with 14 drives as backup, it's impractical to move and update them offsite. I consider my original discs as the second backup and if something catastrophic enough happens to kill two of the three sets, I'll have much bigger things to worry about.
I do have two backups of my most important data ~500GB worth with the second in a fire resistant case at home with my tax papers (which are all online anyway).
I know the feeling, though not at quite the quota size you're dealing with -- while I've got literally dozens of hard drives scattered around my house with stuff collected on them over the years, my main "archive/backup" situation is, Three 4tb drives, two on-site (one is my "daily use" drive, in an NAS, the other is a backup of that daily use drive), and one I take back and forth to my office at work, theoretically a safe-enough location.) But it's enough to try to keep all drives synced, I try to do it at least weekly but come to think of it, it's been at least a month since I backed up the off-site backup.
Though I do make sure to keep a critical backup of stuff I just absolutely would be gutted if I lost, on at least another three drives, one of those in a safe-deposit box ... so I'm okay. I think. Mostly at this point I'm consigned to the fact that if something happened in my life where I'd need to resort to having to start setting things up again from backup -- that would be the least of my problems.
Same here and amen.
A Downloader that works with the UK's Channel4 aka All4
By pooksahib in forum Video Streaming DownloadingReplies: 9Last Post: 21st Feb 2023, 06:25 -
A tale of the importance of backups...
By lingyi in forum Newbie / General discussionsReplies: 17Last Post: 30th Nov 2018, 17:51 -
A Tale of 4 Bluetooth Dongles
By Seeker47 in forum ComputerReplies: 11Last Post: 21st Apr 2017, 10:34 -
What's your method for backups?
By hogger129 in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2016, 00:42 -
Is smooth motion a myth? (aka. how to retain the "live" feel of videos)
By jc909 in forum DVD RippingReplies: 7Last Post: 15th Mar 2016, 03:37
