Hi all, hope somebody can solve an issue for me. I've picked up a mint Ferguson FC16 S-VHS camcorder, that seems perfect except for one issue.
When playing back footage, the standard VHS output is distorted and fuzzy. I've outputted via AV-out (Scart composite) and RF, same results. Weirdly, when I switch to S-VHS playback, the picture stabilises and is perfect but in black and white. As soon as I switch back to VHS playback, colour returns but the picture distorts. I've tried a new VHS tape, old movie releases, same results. Also I've plugged into a modern Sony TV (Scart composite) and old Casio portable (RF in). I'm not recording in S-VHS or attempting to play S-VHS tapes at all yet. Any thoughts or advice would be much appreciated.
Can you view the playback on the viewfinder?
Perhaps you can post a smartphone video to make it more clear to us exactly what you're seeing. -
I can view the playback on the viewfinder yes, in black and white. I can also see the live feed in both S-VHS and VHS mode on my TV. It's when engaging the playback of a tape in VHS mode the problems occur. I will try to sort a video to demonstrate, but it looks like an out of tune tv station, with a distorted fuzzy image. Sometimes with lots of horizontal or diagonal banding across the screen. As soon as S-VHS playback is engaged, it goes black and white and a stable image. Almost as if the playback heads can't handle a colour image. fyi- all the settings on the camera are set correct.
Sony Camcorder TRV815 Hi8 old tapes won't playback in camcorder
By Dforsythe in forum Newbie / General discussionsReplies: 11Last Post: 9th Dec 2019, 16:21 -
Playback issues from older camcorder
By CuriousJane in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 25th Jan 2018, 18:23 -
8mm Camcorder Playback Distortion?
By kamkorder in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 31st Dec 2017, 20:16 -
Distorted audio from VHS tape
By KortschKo in forum AudioReplies: 8Last Post: 29th Aug 2016, 19:05 -
How to connect old VHS Camcorder to TV for Playback
By VHS-C98 in forum Newbie / General discussionsReplies: 7Last Post: 13th Dec 2015, 13:45
