Is it possible to copy a dvd movie on to a usb stick, so that it's watchable on a portable dvd player?
If, as you say, you have a portable dvd player, would you not actually run the dvd on it?
Canon C100 mk2 - Dell XPS8700 i7 - Win 10 - 24gb RAM - GTX 1060/6GB - DaVinci Resolve Studio 18.6.3 - Blackmagic Speed Editor - Presonus Faderport 1 - 3 calibrated screens -
You'll probably have to convert to the video to whatever file type and container the player supports. Check your manual for details.
yes but it depends. If your portable DVD player supports MKV container then you could simply use MakeMKV to make a mkv of the movie title. No menu's etc... That's probably the quickest and simplest. If the player doesn't support MKV then check the manual to see what format it does support
Blu ray player 3D support arabic encoding subtitle for USB Movies
By cccf25 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Feb 2018, 16:13 -
Fix: TV or player not recognizing USB memory stick
By Doogy2Shox in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th May 2017, 14:47 -
Which video player is better to watch 4k movies?
By Nasick in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2016, 08:55 -
Blu-ray Player Not Recognising USB Stick
By Teac23 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th May 2015, 18:12 -
Can I Use Windows Media Player to burn movies DVD To Watch on TV
By poochokid in forum Authoring (DVD)Replies: 2Last Post: 23rd Jan 2015, 03:24
