I've encoded a mpg file (vcd ntsc) with flask+cce
I got the finished file and a subtitled file (SSA)
I've tried virtualdub to add sub via subtitler filter
but I have to re-encode the mpg file again.
Is there a better way to do this without re-encode again?
thank you
Nemoatlantis
You can do it all in one time.
1 - rip the DVD (with smartripper, or whatever you like)
2 - Use DVD2AVI to create a audio part, and D2V file
3 - Use the program VFAPIconv to convert the D2V file to D2V-VFAPI file (takes about 05 seconds)
4 - Rip the subtitles as you have done before.
5 - Convert the subtitles to SSA
6 - Open Virtual dub, and open the D2V-VFAPI file as video source.
7 - Add the subtitles, and use the preview option to see if they are okay.
8 - Frameserve it in Virtual Dub (a VDR file will be created)
9 - OPen TMPGEnc and load the VDR file as the video source.
10 - Load in TMPGEnc the WAV file created by DVD2AVI as the audio source.
11 - Done, you'll have a great VCD with subtitles.
To get some usefull guides, please check:
http://www.flexion.org
The Dutchman
Easy way to add a Countdown Timer to a video
By kelemvor in forum EditingReplies: 0Last Post: 15th Jun 2010, 22:18 -
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 15:47 -
Easy Add Subs to episodes
By KnightHeart in forum SubtitleReplies: 2Last Post: 22nd Jul 2009, 14:34 -
Easy way to add borders to h264 video?
By cbl016 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2008, 02:51 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
