Hi all...
I am having this strange problem with easySUP where I need to convert srt to PGS format. The program was working fine until recently where I think few weeks ago I had to uninstall and re-install some codecs. Now it always ends up with this result: Error Processing subtitles!
I would appreciate any help. I tried to uninstall all codecs and then install only LAV filters with xySubfilter and VSFilter. Also, madVR is installed.
the problem always arise after avs2bdnxml finishes its part, the log is listed below:
[12:07:55] Subtitle file loaded (ABC.srt)
[12:07:56] Video properties imported! (ABC.mkv)
[12:07:56] Video: 1280x720 @ 23.976, Duration: 647 sec (15512 frames)
[12:08:00] Subtitle processing (step 1)...
[12:08:05] Done!
[12:08:10] Subtitle processing (step 1)...
[12:08:28] Subtitle processing (step 2)...
[12:08:29] Error processing subtitles!
[12:08:31] Done!
Any clue?!
Results 1 to 1 of 1
Processing video
By carlmart in forum Video ConversionReplies: 8Last Post: 17th Apr 2019, 11:52 -
how to post processing using AVIMux 2.6.8.
By LadyTaz in forum Video ConversionReplies: 0Last Post: 3rd Mar 2019, 18:39 -
easySUP not working
By tommy2010 in forum Blu-ray RippingReplies: 8Last Post: 28th Dec 2017, 14:44 -
multiAVCHD - Error converting subtitles! (java?)/tsMuxeR failed to process
By Colek in forum Authoring (Blu-ray)Replies: 0Last Post: 10th Sep 2015, 13:30 -
tsMuxer Error 254 with Subtitles on Mavericks/Yosemite
By Inquisitus in forum MacReplies: 2Last Post: 18th Apr 2015, 10:43
