Hi, I've been capturing video and burning some VCDs and some SVCDs but the quality isn't to great. I've burned other videos (not created by me) on (s)VCD that have a lower bitrate and have better quality than mine. I would like to burn at the lowest bitrate but get good quality (preferably quality but I want to fit the most I can on one cd). What am I doing wrong?
I capture real time MPEGI/II with my AVERTV PVR on a
P4 1.6ghz
60gig HDD
512DDR MB
The best results I've created have been with 2500kb video and
224kb audio @ 352x240
but I've downloaded videos of 1700kb video and 256kb audio @ 352x240 with excellent quality, comparable to what I capture with.
Please help!!!
The difference in quality might be the source. When you capture video from VHS tape, you can't do better than tape itself. If your tape is noisy and crappy, your capture and conversion will go downhill.
The high-quality stuff you downloaded might be ripped off from DVD source, which is much better than VHS capture. As a result, conversion quality improves significantly. And remember, VCD format is no better than VHS. [/quote] -
usually, something has to give...either # of discs...or the quality...
obviously, the more discs u willing to put the movie on, the higher the quality will be...if you wanna fit as much as possible on one disc w/o losing too much quality, i suggest SVCD, or maybe even xVCD...
standard VCD 2.0 is getting outdated and low quality (crappy bitrate, CBR not nearly as good as VBR, low resolution)
keep on mind there are things u can do to increase quality w/o increasing filesize (multiple pass VBR, high motion search accuracy, higher resolution)
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 19:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 02:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 14:13 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18
