Hi,
my first post here
I have a couple of hours of home made recordings in mp4. The clips were captured with analog and digital 8 cams, in dv, edited and exported in mpeg-2 for making DVDs. Afterwards I converted them into mp4-Files.
Now I want to re-edit, making smaller clips, joining scenes, but without using software that re-encodes the mp4 because of a matter of time. I dont need effects, etc, just cutting. Can you recomend an easy tool for this purpose?
Thanks in advance
Frank
If you want to make your life more pleasant and maintain quality, use the DV clips to edit and then output the finished project to mp4. Any NLE (except Resolve) can handle this, including the trial period of Premiere.
If you insist on using the 3rd generation mp4s, use a smart renderer like VideoRedo or TMPGenc Smart Renderer. -
Thanks a lot for your answer. Unfortunately I donīt have the DV-files anymore and capturing again is too much work. In that time there were no strorage options for such big flies. I remember, TMPEC had very good encoders, so I will give it a try with TMPGEnc Smart Render.
I also found Avidemux, it cuts and joins Mp4-Material. For my purpose it will be probably sufficient. It doesnīt re-encode what saves a lot of time.
Greetings
Frank -
It will lossless cut only cut on keyframes (just like any lossless editor). There may be several seconds between keyframes. If you want frame accurate cuts it will have to re-encode the entire video. The other editors will only re-encode the cut GOPs -- a few frames (or seconds) at the cuts.
If you still have the mpeg2 files or DVDs, VideoRedo and TMPGenc and AviDemux will handle those as well. (AviDemux, with the same limitations jagabo mentioned above, though with shorter GOPs.) Trying to find a way to save you a generation here, obviously the actual editing will be a little less responsive than with DV.
I just need to change the encoding date in an mp4
By carslberg in forum Newbie / General discussionsReplies: 33Last Post: 18th Apr 2022, 16:27 -
Convert TS to MP4 without re-encoding?
By kingmustard123 in forum EditingReplies: 4Last Post: 24th Oct 2017, 13:07 -
Trim an HD MP4 without re-encoding?
By nigelmercier in forum EditingReplies: 6Last Post: 2nd Apr 2016, 09:25 -
Rotate MP4 Video without re-encoding ?
By DonSeenu in forum Newbie / General discussionsReplies: 7Last Post: 2nd Nov 2015, 22:58 -
Fix mp4 fps without re-encoding?
By TubeBar in forum Video ConversionReplies: 6Last Post: 6th Apr 2015, 11:25
