Hi
I've attached an USB drive to my Android Box that contains all my videos. The drive is formatted with FAT32.
When I add a source in Kodi, I can see the drive under storage/571E-D8E4 (this alpha-numeric reprensents the USB port name I guess). I can now browse the drive but I cannot access to the sub-folders, even though I can see them. When I click on one of them, nothing happens.
So, I added the root folder to a source and selected the Scan recursively option. But Kodi only added the few movies that were in the root, but nothing from the /movies folder.
Is it a limitation from Kodi ? should I put all movies at the root level ? otherwise, what should I do ?
thanks
	FAT32 has 4GB file size limit, try formatting the USB drive as NTFS
 and try again to see if you can access the sub-folders
	OP's main machine is a Mac. Format to exFAT is compatible with both Mac and PC.
  media player with network access to connected usb hdd?By elterry in forum Media Center PC / MediaCentersReplies: 13Last Post: 20th May 2019, 12:54
  Still seeking media player network access connected usb hdd. NOT streamingBy elterry in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Mar 2019, 04:00
  BD Player that will play folders/iso from USB including menus?By JoeKlein in forum DVD & Blu-ray PlayersReplies: 16Last Post: 9th Dec 2017, 00:27
  Can 1TB WD MyPassport drive be used as regular external drive?By Ai Haibara in forum ComputerReplies: 12Last Post: 27th Sep 2017, 07:07
  Unable to access my external Hard driveBy aruwin in forum ComputerReplies: 36Last Post: 15th Oct 2016, 16:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
