Results 1 to 1 of 1
    Dec 2019
    Lombard
    hi
    https://1080ppornlist.com/
    I'm using VSDC.
    I added an image to my scene. then added to the image several linked "movement" animations.
    i.e., the first movement lasts a second and the object slides up. the 2nd movement starts immediately after the first movement, lasts a second, and slides to the right, etc
    In the preview, it works fine.
    But when I in the export, it doesn't work properly.
    It's as if it takes the start point of the first movement and moves the object to the end of the last movement point and ignores all intermediary movement points.
    I'd appreciate any help
    thanks
