Results 1 to 10 of 10
  1. Member Gary Salisbury's Avatar
    Dec 2019
    San Diego, California, USA
    Yes, another newbie question.
    I have a favorite movie on Blu-ray that I want to capture single frames from for use as Windows 10 desktop wallpaper in 1920x1080 resolution. What is the easiest way to do this?
    Gary in not so sunny San Diego today
    Aug 2017
    Alt+PrintScreen and then Ctrl+v in Paint?
  3. I'm a Super Moderator johns0's Avatar
    canada
    How are you viewing the blu-ray?Is it still in your blu-ray player or in your computer blu-ray burner/player or already ripped to your hard drive?
  4. Member Gary Salisbury's Avatar
    Dec 2019
    I am viewing on my computer from the original blu-ray disk. Would it make a difference if it was already ripped? Maybe there is copy protection on the bluray disk?
    canada
    The program you are using to watch it should have a capture feature,doing a print screen capture won't work due there being a video hardware layer.
  6. Member Gary Salisbury's Avatar
    Dec 2019
    Oh, I forgot all about that one. So I start the movie, go full screen, and when the scene come up that I want a shot of I just ctrl-prt sc and I get a 1920x1080 shot. Good however, the movie appears to be played in 1920x810 mode so I get black bars above and below the screen image. Looks like I might have to do some picture editing.
    It appears my max resolution on my HP Envy is 1920x1080 so I guess I am limited to that resolution for capturing. Generally speaking, there are only two types of resolution for a commercial Blu-ray disc: 1080P (1920x1080 pixels) and 4K UHD (3840x2160 pixels). So even if I had a 4kUHD disk, I wouldn't be able to see or capture at that higher resolution, correct?
  7. Member Gary Salisbury's Avatar
    Dec 2019
    I have VLC Media Player so I will check that idea out. Thanks.
  8. Member Gary Salisbury's Avatar
    Dec 2019
    So are you saying that I would need to rip it first? Where can I find Blu-Ray ripping instructions? Are there recommendation for the best software to use?
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    no play the video with vlc. pause at the frame you want. click on "video/take snapshot".
    Aug 2006
    The ability to take snapshots while playing an original Blu-ray disc has long been disabled in Blu-ray player software that is licensed by the Blu-ray Disc Association (Cyberlink PowerDVD Pro, Cyberlink PowerDVD Ultra and Corel WinDVD Pro) as a condition of licensing.
    Blu-ray player software that has the ability to take snapshots but has no BDA license, for example, DVDFab Player, can make snapshots while playing an original Blu-ray disc.
    If the Blu-ray movie is ripped to a file, video player software with the ability to take snapshots, for example, VLC or PotPlayer, can make them.
    Last edited by usually_quiet; 10th Dec 2019 at 00:24. Reason: edited second paragraph for clarity, corrected punctuation
