Using Corel's VideoStudio X10.5, I edited an MP4 video clip with a frame size of 480x720p (portrait 0.667:1 and not 720x480 that is 1.50:1) and wish to save it with the same properties. I tried every option, including "Custom" for "Mobile"; but the "User-defined" setting is grayed. Any way to get VS to save the file with the original 480x720p orientation?
Djard
medfaith@yahoo.com -
Never mind, I learned that VS renders 480x720p only in AVI or MOV format, and that compression must firstly be disabled. Skip the General tab, go to Compression tab, set to "None" then "User-defined" will be enabled in "General" tab. Sigh!
Djard
medfaith@yahoo.com
DVI-D-HDMI Adapter does not support 2K Resolution?
By therock003 in forum Newbie / General discussionsReplies: 37Last Post: 30th Dec 2018, 12:20 -
Corel PaintShop Pro X9
By budwzr in forum EditingReplies: 13Last Post: 10th Apr 2017, 11:42 -
Converting 720p to 480p (Getting rid of black bars on the side of 720p)
By fri3ndlygiant in forum Video ConversionReplies: 5Last Post: 22nd Mar 2016, 05:20 -
Best Quality encoding from 1080p to 720p & 720p to 720p in Xvid4PSP?
By Odie111 in forum Video ConversionReplies: 8Last Post: 9th Jan 2016, 16:42 -
Do I need to resize 1080p PGS subs to 720p when making 720p AVCHD ???
By FulciLives in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Aug 2015, 12:26
