Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. I have been trying to encode some videos to x265 with 10-bit encoding, & have experimented with both TMPGenc Video Mastering Works & also DVDFab. On both occasions the software have created videos that are too dark. Is there any reason for this & is there a way to rectify the problem?
  2. Two encoders giving the same dark output hints that you have a playback problem, not an encoding problem. Upload a short sample, before and after.
  3. I donít see how it can be a playback problem when the same problem occurs when played on numerous machines that I have tried it through?
    I Iíve put the result through a few software players as well as on USB via 2 different bluray players, a media player, an HDTV and video projector?
    Iíve tried a few different recordings with the same problem.
    It also looks like the recordings are much darker with DVDFab than TMPGenc.
    Iíll try to upload a sample later.
  4. May be missing VUI flags,...
    users currently on my ignore list: deadrats, Stears555
  5. Originally Posted by magnu View Post
    You should mentioned all that in your initial post. In any case, samples will help diagnose the problem.
  6. Originally Posted by Selur View Post
    How can I find out? Any software that will tell me and, if so, place them in the videos?
  7. Post a detailed MediaInfo analysis of the source and the reencode,...
