Hi,
I have a few mp4 videos where (with headphones) the left eared audio needs to be removed, but I want to keep the right eared audio. On mediainfo it says there is one audio stream, but 2 channels. Here is some info:
Audio
Format : AAC
Format profile : LC
Codec ID : mp4a-40-2
Duration : 1 h 24 min
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Is there a solution to this? Would have thought the fix is relatively simple but searching online I cannot find one. As you may have guessed, I am not a particulary technical person.
Thanks very much for your help, and if there is more information required please say so.
With one video and stereo audio you could try
Code:ffmpeg -i video.mp4 -c:v copy -filter_complex "[0:a]channelsplit=channel_layout=stereo:channels=FR[right]" -map "[right]" -map 0:0 One_track.mp4
1. Extract audio and convert to PCM WAV audio: the free AOA AudioExtractor
2. Remove the one channel followed by turning the remaining one to dual mono followed by saving as AAC audio: the free Audacity
3. Replace original audio with the new one: the free MP4Box with a GUI -
@Lol
This is a Command Line Interface (CLI) command.
You should have ffmpeg in your path or type the path before ffmpeg.
You open a command prompt and paste in the command.
[Attachment 51056 - Click to enlarge] -
Thanks you all, I used @manono 's solution, and after some trial & error it worked
Best program for MKV to MP4 or just encoding the audio?
By kkiller23 in forum Newbie / General discussionsReplies: 7Last Post: 28th Oct 2019, 17:08 -
is there any side effect when encoding without audio? (Megui)
By rudolfp in forum Video ConversionReplies: 18Last Post: 8th Dec 2017, 15:34 -
How to Create 3D Blu ray disc from a downloaded 3D side by side MP4 movie
By cdjhall in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2017, 23:46 -
how to remove audio from MP4 easy
By ecos in forum Newbie / General discussionsReplies: 7Last Post: 18th Jul 2015, 18:10
