  1. I'm a long time viewer of these forums but this is my first time posting.
    I'm attempting to download streams of a show using YouTube-DL and I think I have located the m3u8 files for each but I keep getting code 1. No login is required.
    Here are the links to the show on the site:
    Season 1 Episodes
    Season 2 Episodes
    This was my output for the first episode:
    Last login: Fri Dec  6 19:33:56 on ttys000
    The default interactive shell is now zsh.
    To update your account to use zsh, please run `chsh -s /bin/zsh`.
    For more details, please visit https://support.apple.com/kb/HT208050.
    Roberts-Mac-Pro:~ robert$ youtube-dl https://content.uplynk.com/ext/b82f6b1017f64c7b872b8d80b276b280/f231173a-cb0a-42ed-8e00-fe788aabd8af.m3u8?tc=1&ct=a&rn=3688160511&exp=1575764386&eid=f231173a-cb0a-42ed-8e00-fe788aabd8af&oid=b82f6b1017f64c7b872b8d80b276b280&rmt=fps&ad=prerollbasic&ad.lib=christmaspromo&ad.preroll=1&sig=93c3a98346a6b7eb64ebbaa0865f0fbd33165305fa2c1ee80814c393d53ac153
    [1] 9674
    [2] 9675
    [3] 9676
    [4] 9677
    [5] 9678
    [6] 9679
    [7] 9680
    [8] 9681
    [9] 9682
    [10] 9683
    -bash: ad.lib=christmaspromo: command not found
    -bash: ad.preroll=1: command not found
    [2]   Done                    ct=a
    [3]   Done                    rn=3688160511
    [4]   Done                    exp=1575764386
    [5]   Done                    eid=f231173a-cb0a-42ed-8e00-fe788aabd8af
    [6]   Done                    oid=b82f6b1017f64c7b872b8d80b276b280
    [7]   Done                    rmt=fps
    [8]   Done                    ad=prerollbasic
    [9]-  Exit 127                ad.lib=christmaspromo
    [10]+  Exit 127                ad.preroll=1
    Roberts-Mac-Pro:~ robert$ [uplynk] f231173a-cb0a-42ed-8e00-fe788aabd8af: Downloading m3u8 information
    [uplynk] f231173a-cb0a-42ed-8e00-fe788aabd8af: Downloading JSON metadata
    [hlsnative] Downloading m3u8 manifest
    Roberts-Mac-Pro:~ robert$ WARNING: hlsnative has detected features it does not support, extraction will be delegated to ffmpeg
    [download] Destination: 'Dwight in Shining Armor -s1e1-Pilot'-38add894d29c46a89ec45b54599686a0.mp4
    Roberts-Mac-Pro:~ robert$ ffmpeg version 4.2.1 Copyright (c) 2000-2019 the FFmpeg developers
      built with Apple clang version 11.0.0 (clang-1100.0.33.8)
      configuration: --prefix=/usr/local/Cellar/ffmpeg/4.2.1_2 --enable-shared --enable-pthreads --enable-version3 --enable-avresample --cc=clang --host-cflags='-I/Library/Java/JavaVirtualMachines/adoptopenjdk-13.jdk/Contents/Home/include -I/Library/Java/JavaVirtualMachines/adoptopenjdk-13.jdk/Contents/Home/include/darwin -fno-stack-check' --host-ldflags= --enable-ffplay --enable-gnutls --enable-gpl --enable-libaom --enable-libbluray --enable-libmp3lame --enable-libopus --enable-librubberband --enable-libsnappy --enable-libtesseract --enable-libtheora --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libxvid --enable-lzma --enable-libfontconfig --enable-libfreetype --enable-frei0r --enable-libass --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librtmp --enable-libspeex --enable-libsoxr --enable-videotoolbox --disable-libjack --disable-indev=jack
      libavutil      56. 31.100 / 56. 31.100
      libavcodec     58. 54.100 / 58. 54.100
      libavformat    58. 29.100 / 58. 29.100
      libavdevice    58.  8.100 / 58.  8.100
      libavfilter     7. 57.100 /  7. 57.100
      libavresample   4.  0.  0 /  4.  0.  0
      libswscale      5.  5.100 /  5.  5.100
      libswresample   3.  5.100 /  3.  5.100
      libpostproc    55.  5.100 / 55.  5.100
    [hls @ 0x7fa10b80be00] Skip ('#EXT-X-VERSION:5')
    [hls @ 0x7fa10b80be00] Skip ('#UPLYNK-SEGMENT: 38add894d29c46a89ec45b54599686a0,00000000,segment')
    [hls @ 0x7fa10b80be00] Skip ('#UPLYNK-KEY:https://content-ausc2.uplynk.com/check?b=38add894d29c46a89ec45b54599686a0&v=38add894d29c46a89ec45b54599686a0&pbs=')
    [hls @ 0x7fa10b80be00] Skip ('#EXT-X-PROGRAM-DATE-TIME:2019-12-07T00:34:07.541000+00:00')
    [hls @ 0x7fa10b80be00] Opening 'https://content-ausc2.uplynk.com/check2?b=38add894d29c46a89ec45b54599686a0&v=38add894d29c46a89ec45b54599686a0&r=g&pbs=' for reading
    [https @ 0x7fa10b725680] HTTP error 403 Forbidden
    [hls @ 0x7fa10b80be00] Unable to open key file https://content-ausc2.uplynk.com/check2?b=38add894d29c46a89ec45b54599686a0&v=38add894d29c46a89ec45b54599686a0&r=g&pbs=
    [hls @ 0x7fa10b80be00] Opening 'crypto+http://x-default-stgec.uplynk.com/ausc/slices/38a/b82f6b1017f64c7b872b8d80b276b280/38add894d29c46a89ec45b54599686a0/G00000000.ts?x=0&si=0' for reading
    [hls @ 0x7fa10b80be00] Error when loading first segment 'http://x-default-stgec.uplynk.com/ausc/slices/38a/b82f6b1017f64c7b872b8d80b276b280/38add894d29c46a89ec45b54599686a0/G00000000.ts?x=0&si=0'
    http://content-ausc2.uplynk.com/38add894d29c46a89ec45b54599686a0/g.m3u8: Invalid data found when processing input
    ERROR: ffmpeg exited with code 1
    Any help would be greatly appreciated.
  2. Content protected (DRM).
    Nov 2015
    Campuchia - Sapoche
    i try youtube-dl + m3u8 but not thing work (get HTTP Error 403: Forbidden)
    [hlsnative] Total fragments: 362
    c45b54599686a0.mp4
    [download] 0.3% of ~1.10GiB at 2.20MiB/s ETA 09:54 ERROR: unable to down
    load video data: HTTP Error 403: Forbidden
  4. Interesting. I am using Tubedigger version 6.6.1 and I was able to download no problem. However, I initially got a message that the site was not supported. (Every time in the past when I get such message from Tubedigger, indeed you couldn't download). I downloaded
    dwight-in-shining-armor-lotions-and-potions
    in the lowest resolution (256x144), however, higher resolutions (up to 720p )were shown in the available downloads.
    Link to video (24 minutes,30MB):
    https://mega.nz/#!NaJjySxR!lwrO1ho-nTX0yuaLJqWqOtk57W6Jy_cskOHoXDiuhX8
    You can try the latest Tubedigger for free, but the free version will download only 50% of the video. If you want to buy the software it costs $15 (google: Tubedigger coupon code). I've only bought one software since I started using computers in 2001, and that was Tubedigger.
  5. yes me also initially got a message that the site was not supported.
    i used latest version of tdigg (685) but anyway download start and finish without error and video file see correctly.
    @ jimdagys
    why don't update your software? license also applies to update versions...
