Hey, I'm new to video editing. I searched about my problem but didn't got any proper answer because I don't know what this feature is called.
I needed to how to add moving line on the boundary/edge of the video? This line start moving when video starts and keep increasing and meets when video ends.
Also what is this feature called?
[Attachment 51035 - Click to enlarge]
Overlay a green bar at the right. The y position varies with the frame number or time.
Any NLE can do this. An example using AviSynth:
Code:function ProgressBar(clip v, clip bar, int pos) { Overlay(v, bar, x=v.width-4, y=v.height-pos) } ColorBars().Trim(0,100).ShowFrameNumber(x=10, y=20) bar = BlankClip(color=$00ff00).Crop(0,0,4,-0) Animate(0,framecount-1,"ProgressBar", last,bar,0, last,bar,last.height)
"rectangular progress bar" , or "animated stroke", or "animated path"
There many ways to do this - you could do it as an animated overlay, or mask reveal, or path animation, or html5 code, or some plugins . So it depends on what program you are using
Plugins are probably easiest for this task. They typically enable you to "draw" a line along a mask path. You just set a keyframe for the start and end (0% to 100%). e.g. "stroke" in after effects. Since it "follows" a mask you can do any shape, it doesn't have to be a rectangle. It can be a circle or text, or even complex shapes or text, calligraphy etc..
Add punctuation to each line in Aegisub automatically
By PannenkoekenNL in forum SubtitleReplies: 1Last Post: 7th Jan 2018, 09:32 -
Sony Vegas: How to add this sort of moving background effect?
By rocco123 in forum EditingReplies: 2Last Post: 26th Feb 2017, 09:53 -
Its possible to remove a moving watermark from a video ?
By Darth_Vader in forum Newbie / General discussionsReplies: 10Last Post: 23rd Jan 2017, 10:41 -
Add dash to a continuing subtitle line?
By Rob- in forum SubtitleReplies: 5Last Post: 23rd Sep 2016, 09:31 -
placing a moving picture into another video
By tomchook in forum EditingReplies: 4Last Post: 9th Oct 2015, 18:25
