I've been using a DMR-ES15 as a passthrough for VHS and Beta, it works great for VHS but beta it is creating this odd pattern on the screen, visible more in some videos than others but many it is very noticeable... See the pics and samples (the screenshots are from the deinterlaced file, the captures are raw) Also the NR is off in the Panasonic.
No Passthrough
[Attachment 51022 - Click to enlarge]
DMR ES-15 (Zoom in)
[Attachment 51023 - Click to enlarge]
Any ideas? Could the DMR-ES15 be defective (or the beta machine have some problem)?
Many of the much worse quality beta recordings the effect is pretty much not even there.
Thanks..
Noise like that is usually some kind of noise/interference. Make sure all devices are plugged into the same power strip. Remove other devices from the power strip (or wall socket). If there's a cable TV connection -- disconnect it. Make sure to use decent (not necessarily expensive) cables.
Betamax digitizing help of a rare film.
By LetThemEatCake in forum Newbie / General discussionsReplies: 370Last Post: 30th Sep 2019, 12:39 -
How do you deal with frame repeats - where the pattern briefly changes?
By jaibubwan in forum Video ConversionReplies: 4Last Post: 23rd Mar 2018, 13:50 -
Strange 3-3 pattern?
By Downgraded286 in forum Video ConversionReplies: 21Last Post: 14th Dec 2016, 17:51 -
Test Pattern on YouTube
By chris319 in forum Video Streaming DownloadingReplies: 44Last Post: 2nd Jun 2016, 11:22 -
Android madness..... too many pattern attempts
By hello_hello in forum ComputerReplies: 14Last Post: 21st Nov 2015, 03:59
