hello,
Would it be possible to build a pc with several capture cards (USB and/or PCI) to capture several analog video sources at the same time?
Is it possible to use several instances of virtualdub, each instance would use a different video capture card.
(I have already had blue screen problems with virtualdub).
Therefore, it is possible to do the same with multiple minidv acquisition via several FireWire PCI cards.
The idea is to build a pc with a SSD hard disk of one terabyte, several external hard disks in USB 3 or internals.
Two FireWire connections and two or three video capture cards.
16 gigas of RAM and an octocoreur cpu.
The purpose of course is to be able to do analog or old video formats capture, saving time and taking advantage of the power of today's computers.
(and by the way, thanks for this forum, it help a lot)
Hi, I have a FireWire card with 3 ports and tried two DV camcorders simultaneously with VirtualDub and work well, copied VirtualDub installation folder, renamed them VirtualDub 1 and 2 and selected the correspondent DV camcorder on each instance of VirtualDub.
Hope it helps.
Lucas -
All. That's what makes them capture cards, as opposed to transfer cards like Firewire.
How do I set the analog video capture resolution in Virtualdub?
By spotty in forum Capturing and VCRReplies: 5Last Post: 10th Dec 2018, 03:51 -
Convert multiple video files to multiple DVD ISOs
By tons of guns in forum Video ConversionReplies: 1Last Post: 14th Jul 2017, 19:52 -
running multiple files in sequence possible with ffmpeg?
By sommers in forum Newbie / General discussionsReplies: 6Last Post: 4th Jun 2017, 09:19 -
Windows Software to Merge Multiple Video Inputs Into Single Camera Output?
By pone44 in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2017, 15:54 -
Multiple camera simultaneous capture
By annalynngus in forum Capturing and VCRReplies: 5Last Post: 22nd Oct 2015, 12:35
