Hello,
Allow me to begin with the fact that I have been playing around with ffmpeg enough to make it work a couple of times and it allowed me to create legit videos that were worthy of using afterwards. However I also need to mention that throughout this learning curve that easily finding THE proper information on what (I think) are simple matters proves sometimes very complicated.
This is why I have registered on this forum: because this community seems to know their stuff. And with that being said, I am trying to encode a slideshow from some jpegs(all standardized to 4096x2160) and 1x wav(freshly extracted) files using the following:
And the result is generally a myslideshow.mp4 that will display all of my jpegs files img???.jpg over the my.wav that were all sharing the same folder. As it should be. And it happens on most of the days.$ ffmpeg -loop 1 -r 1/10 -i img%03d.jpg -i my.wav -c:v libx264 -vf fps=1 -pix_fmt yuv420p -shortest myslideshow.mp4
But on the bad days the myslideshow.mp4 file will play correctly(showing 1 picture every 10 seconds per requested) but it will also have added an extra 2 minutes of silence at the end. And during that silence period jpegs will continue to slideshow. Why is that??
As I already said I spent a couple of nights reading on how ffmpeg works and over that time period I discovered the -af "adelay=1|1" switch. But I am not sure that I need to go that far since my goal is to encode simple videos from simply and standardized jpegs & waves in a quick way and in batch mode. Therefore I am on the look-out for a basic recipe(command line) that I can constantly reuse and that will always work while keeping the esoteric stuff away (like calculating audio & video lenght and combining them after, such as what the adelay switch hints me at doing).
So, dear VideoHelp community, can anyone of you please guide me on how to use ffmpeg properly so that each time I encode a .mp4 file that they never end with a 2+ minutes of silence at the end while only displaying pictures?
Results 1 to 1 of 1
~RD
FFMPEG transcoding gone down after few Minutes.
By drpaudel in forum Newbie / General discussionsReplies: 0Last Post: 20th Sep 2018, 20:36 -
ffmpeg Creating slideshow from images fails
By Budman1 in forum Video ConversionReplies: 1Last Post: 19th Feb 2018, 03:44 -
[SOLVED] FFMPEG Slideshow (Tried looking online and can't get it to work).
By Tolwyn in forum Newbie / General discussionsReplies: 21Last Post: 15th Aug 2017, 22:18 -
Will a Sony DVCAM DSR-20MDP play 60 minutes on a tape recorded 60 minutes?
By snufsis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jun 2017, 20:00 -
Audio fade after 15 minutes
By RexBuster in forum AudioReplies: 5Last Post: 29th Oct 2015, 16:23
