Hi, everyone ! Simple question: going from music concert interlaced PAL DVD to mkv (MPEG or H.264). But don't know which the best way to keep original AR (16:9 display) after encoding. Thanks in advance !
Original VOB's Mediainfo:
General
Complete name : D:\Download\BRMC - Live In London (2010)\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 33mn 44s
Overall bit rate : 4 243 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 33mn 44s
Bit rate mode : Variable
Bit rate : 3 966 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.383
Time code of first frame : 01:00:00:00
Time code source : Group of pictures header
Stream size : 957 MiB (93%)
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 33mn 44s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 46.3 MiB (5%)
AviSynth script (deinterlace by QTGMC):
SetMemoryMax(512)
LoadPlugin("C:\Program Files (x86)\DVD\AviSynth+\plugins64\DGDecode.dll")
LoadPlugin("C:\Program Files (x86)\DVD\AviSynth+\plugins64\masktools2.dll")
LoadPlugin("C:\Program Files (x86)\DVD\AviSynth+\plugins64\MVTools2.dll")
LoadPlugin("C:\Program Files (x86)\DVD\AviSynth+\plugins64\Grunt-x64.dll")
LoadPlugin("C:\Program Files (x86)\DVD\AviSynth+\plugins64\RemoveGrain.dll")
Import("C:\Program Files (x86)\DVD\AviSynth+\plugins64\SRestore.avsi")
Import("C:\Program Files (x86)\DVD\AviSynth+\plugins64\QTGMC.avsi")
MPEG2Source("F:\BRMC.d2v")
QTGMC()
SRestore()
Results 1 to 12 of 12
You said it's PAL interlaced, but this is an NTSC DVD given the specs. If it is interlaced, then you don't need to use srestore. The frame rate should be doubled, which is what you want after deinterlacing. Set the aspect ratio to 16:9 after encoding with MKVToolnix.
Yes, and since there's so much incorrect information in the post, better might be to make available 10 seconds from the DVD so we can have a look.
Oooops, no SRestore ! My bad...
Attached sample. Thanks in advance !!! -
Well, it's field-blended from a PAL source. It turns out your earlier script was correct.
QTGMC()
SRestore()
As for the AR after reencoding, either resize it to a 1.778:1 ratio - one such as 852x480 - or keep the current resolution and set a SAR while encoding. It's 40:33 for a 16:9 NTSC DVD source (I think).Last edited by manono; 2nd Dec 2019 at 18:36.
Actually, Srestore may be appropriate because it looks as if it was originally 25i. (there are some blends)
So to resize just use spline36resize(852,480) to give DAR 16:9
oops - manono beat me to it -
Your source is NTSC. But its source was a progressive PAL video. When the PAL video was converted to interlaced NTSC the frame size was reduced from 720x576 to 720x480 and blended fields were added to go from 25 frames per second to 59.94 fields per second. QTGMC converted 59.94 fields per second to 59.94 frames per second. SRestore() removed all the blended fields leaving the original (except for the frame size) 25 fps progressive PAL frames.
And I wrote "simple question" on first post...Feeling a PRO now !
The encoding just got perfect. Thanks a lot guys !!! -
By the way, QTGMC().SRestore() may not have been right for the other videos you mentioned in post #8. This script is specifically for restoring 25p PAL from 30i NTSC.
Just checked: there is a hashtag (#) before that line on the original generic script and for some reason I took it off this time. Maybe I noticed 'PAL source' the first time I sent it to encoder (Premiere). Honestly, I don't remember...
Cheers !!!
When I use QTGMC to deinterlace 1080i60 content to 1080p60...
By Asterra in forum Video ConversionReplies: 5Last Post: 5th Feb 2019, 21:45 -
newbie to AVISynth & VirtualDub-need help with IVTC & deinterlace via QTGMC
By clashradio in forum Capturing and VCRReplies: 79Last Post: 14th Nov 2018, 21:05 -
What is the difference between Virtualdub's deinterlace filter and QTGMC
By ricardoRF10 in forum EditingReplies: 12Last Post: 20th Jan 2018, 07:32 -
strange QTGMC deinterlace error
By Srivas in forum RestorationReplies: 7Last Post: 30th Jan 2016, 23:36 -
QTGMC doesn't deinterlace
By pub in forum DVD RippingReplies: 5Last Post: 28th Dec 2014, 12:07
