I simply need to use Handbrake to change the resolution on a video and then save the results. The input video is at a standard 720p size (1280x720) and I would to up the output resolution to a standard 1080p size (1920x1080). Could someone offer a suggestion for doing that - starting with the product defaults presented as the program starts up? I am an IT guy but have little or no experience with video. I think I am experiencing feature/capability overload with Handbrake as I try to make this one change and accept all of the defaults it gives me.
Just. Don't do it.
Not necessary for playback, not necessary for editing.
Scott -
Hi Scott,
Sorry but I don't understand what your message means. Are you saying don't use VidCoder or don't increase the output resolution or ?
As I said, I am an IT guy (long-time C++ and C# developer who has designed many, many user interface screens) and I am used to using software with lots of options and parameters but there is simply something on Handbrake that I am missing. VidCoder did the conversion just fine because there was and option for "Manual" under the Sizing tab. It let me do what I have been trying to do on Handbrake. How do I duplicate that "let me pick what resolution I want" option on Handbrake?
As for now, when I try to manually select the output resolution to 1920x1080, it keeps resetting itself to the input resolution. I can't find any combination of options/parameters under the Dimensions tab to let me simply manually select the output size. I have tried every (I think) option on Anamorphic, having the "maintain the input ratio" checked or unchecked, and several different Presets - no combination works. Plus, when I mouse over the size selection control it warns me that the selections only control the dimensions that the output will be stored at and that the display dimensions may come out as something else. The bottom line is that is just want to change the output resolution and, I assume, have it stored that way on disk. I don't want to change the quality (I did figure out how to do that) but just want to change the size. Where am I going wrong? -
Upscaleing it won't give you more detail,if anything it will be worse, just let your monitor or TV upscale it.
Handbrake's best settings to simply burn .srt over a .mkv
By coderkidz in forum SubtitleReplies: 3Last Post: 27th Mar 2019, 06:47 -
change the very low resolution of video to high resolution
By idi0t in forum Newbie / General discussionsReplies: 22Last Post: 1st Jul 2017, 10:51 -
Why does resolution change in handbrake with "keep aspect ratio" checked?
By ikarius in forum Video ConversionReplies: 36Last Post: 2nd Dec 2016, 12:35 -
How to change resolution of Online Video in Pot Player ?
By JohnCale in forum Software PlayingReplies: 0Last Post: 16th Oct 2016, 07:13 -
Change playback speed in Handbrake
By EM1 in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2015, 04:27
