I have some old prerecorded Drum Corps VHS tapes. A few years back I was able to make DVDs (on a now defunct DVD/VHS machine) of some but a couple would not copy. I also have some copy protected VHS that can not be found on DVD that I would like to rip. Many of the devices I see for sale say they don't work on copy protected VHS. These are for me to watch and protect the tapes from damage. Anyone know of a sure way to do this? Would like to keep it under $50.
Pet peeve. You don't RIP a VHS tape. You capture it.
Your $50 budget is unrealistic as you'll need an external Time Base Corrector $$$ to remove the copy protection. Add in a quality VCR and quality capture device and you're looking at 10X+ your budget. The upside is you can resell your equipment and recover most of the cost.
If you're willing to spend the money to do your project correctly and with quality, read these articles and threads:
http://www.digitalfaq.com/editorials/digital-video/professional-analog-workflow.htm
http://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide.html
http://www.digitalfaq.com/forum/marketplace/8057-sale-complete-workflow.html -
Just a follow up on this. I found an article https://www.pcmag.com/feature/365201/how-to-convert-vhs-home-movies-to-dvd I bought the device for $13 and downloaded the free OBS.
As it turns out some of the older Drum Corps tapes must not have had copy guard because this worked just fine. Two of the tapes would copy but the color kept going in and out and lines would distort the picture.
I wonder, is the copy guard detected by the connecting device or the OBS program?
Moral, it you really just want to convert home movies there is no need to spend big bucks. -
Well rats. I am down to only 2 tapes so I am not going to spend big bucks. I like to make mp4 of these so I can watch on my laptop with my bose headset. Watching the vhs on TV is not the same and I don't have the sound system for it. Besides, my wife won't let me buy a big screen TV. A 19 inch laptop gives the same effect.
I'm guessing he means this: https://www.amazon.ca/REDGO-Capture-Converter-Adapter-Support/dp/B01N6WQHPB/ref=sr_1_1...5929788&sr=8-1
Capturing VHS tapes
By mtamimi in forum Capturing and VCRReplies: 7Last Post: 3rd Mar 2018, 01:09 -
Transferring S-VHS Tapes to a PC
By smbecket in forum Capturing and VCRReplies: 6Last Post: 19th Nov 2017, 17:58 -
How to create an mpg, mp3 or mp4 file from VHS? (Using Honestech VHS to DVD
By CambridgeChris in forum Capturing and VCRReplies: 2Last Post: 29th Dec 2016, 10:29 -
I need some help converting my old VHS, VHS-C, and 8mm/Hi8 tapes. Many Q's!
By CZbwoi in forum Capturing and VCRReplies: 80Last Post: 20th Apr 2016, 17:17 -
For the lack of a better term.. recommendations on ripping vhs tapes
By RBCC in forum Capturing and VCRReplies: 5Last Post: 19th Aug 2015, 12:07
