Hi there
I have a multichannel w64 file and would like to boost the LFE channel by +6dB. This is what I have so far:
RaWavSource("C:\audio.w64", 1).AmplifyDB(+6.0,4)
SoundOut()
However my output seems to be louder overall instead of just channel 4. Could it be that channel 4 is not the LFE channel or am I using the function arguments incorrectly?
Thanks would appreciate any help.
You are using it incorrectly.
http://avisynth.nl/index.php/AmplifyAmplifyDB(clip, float amount [, float amount ]...)
So probably something like:
(Assuming LFE is the 4th channel in your file.)Code:AmplifyDB(0.0, 0.0, 0.0, 6.0, 0.0)
Downmixing 6 channel AAC to 2 channel?
By bizzybody in forum Video ConversionReplies: 33Last Post: 12th Nov 2017, 11:19 -
Convert 6 Channel AAC to 6 Channel AC3
By TheRandomOne in forum AudioReplies: 18Last Post: 4th Jul 2017, 11:40 -
How to fix audio that jump from channel to channel?
By midts in forum AudioReplies: 2Last Post: 24th Apr 2017, 08:04 -
NicAudio or FFAudioSource?
By killerteengohan in forum AudioReplies: 1Last Post: 25th Oct 2015, 01:59 -
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32
