Hi,
I've been trying to rip "The fast and the furious" and "the mummy", but everytime, the subtitles are unreadable!
I'm using DVDx with TMPGEnc, and the subtitles are semi-transparent when "use original colors" is checked, and they get like white-bold when uncheked.
What could be wrong?
thanks!
Results 1 to 9 of 9
marcelo_magri
Athlon XP 1600+
ECS K7S5A
256 Mb RAM
Maxtor 5200rpm 40 Gb HD
Riva TNT2 32 Mb Videoboard
Hollywood+ MPEG card
Toshiba 6x DVD-ROM
LG 16x10x40 CD-RW -
well actually if you want beter subs i suggest you use VirtualDub w/ Vobsub filter its a bit harder to set everything up but its worth it check in the guides section to see how to add subs...oh DVDx can only make readable if you encode to SVCD
is there anyway of virtualdub frameserve from dvd?
marcelo_magri
Athlon XP 1600+
ECS K7S5A
256 Mb RAM
Toshiba 6x DVD-ROM
LG 16x10x40 CD-RW -
Nope you have to rip it...if you have a HD problem then i guees it only with DVDx but hey did you try encodeing with TMPGEnc w/ DVDx??
that's what i'm doing, but in the preview window of dvdx, you can notice the poor quality of the subtitles... which would be good to do? convert to avi? which tool can do it with subtitles?
marcelo_magri
Athlon XP 1600+
ECS K7S5A
256 Mb RAM
Toshiba 6x DVD-ROM
LG 16x10x40 CD-RW -
convert to psuedo avi using vfapi-encode...you can then load this into vdub w/ the vobsub filter and add subs the best way..u can then frameserve to tmpgenc
Is there anyway of ripping subtitles from the DVD?
marcelo_magri
Athlon XP 1600+
ECS K7S5A
256 Mb RAM
Toshiba 6x DVD-ROM
LG 16x10x40 CD-RW -
most methods ARE ripping the subs from the DVD....the vobsub/vdub method is one of the best ways to add subs...u don't manually type in the subs yourself if that's wut u were thinkingOriginally Posted by marcelo_magri
Hi,
In the DVDx, try uncheck the Original colors and put the Offset (pixel) = 4
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 08:45 -
By ioakim2an in forum SubtitleReplies: 1Last Post: 17th Aug 2010, 06:52 -
unreadable DVD becomes readable - why? how?
By JohnnyBob in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:11 -
Burning switchable audio and subitles
By imkool in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2008, 05:12 -
Can you make a dvdr unreadable?
By nuffskillz718 in forum Newbie / General discussionsReplies: 11Last Post: 27th May 2007, 05:13
