Hello Everyone!
Recently I wanted to increase the volume of an audio track using FFmpeg, first of all, I had to read a guide on how to do this. But at the end of the guide it says the following:
"Note that the volume filter only adjusts the volume. It does not set the volume"
This confuses me, because Adjust-Increase-Reduce volume is not the same as Set it?
I just want the volume changes to be permanent.
Can someone explain me this please.
Link to the Guide:
https://trac.ffmpeg.org/wiki/AudioVolume
It adjusts the volume relative to its current volume. For example -filter:a "volume=1.5" makes the volume 1.5x louder. It does not set the volume to an absolute loudness. The latter is what all the discussion of normalization is about.
For example, say you have three tracks with "loudness" of 25 percent 50 percent and 100 percent. You apply volume=1.5 to each of them. The new tracks will have loudness values of 37.5 percent, 75 percent, and 150 percent. Normalization to 100 percent would result in all three having 100 percent.Last edited by jagabo; 26th Nov 2019 at 10:20.
FFMPEG AUDIO extraction question?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 8th Nov 2017, 16:05 -
Convert audio part of a video and increase volume by 30% wiht ffmpeg?
By pxstein in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2017, 04:06 -
FFmpeg - Audio question
By Jdan93 in forum AudioReplies: 6Last Post: 31st May 2016, 11:35 -
FFMpeg : Use the "volume" filter for Preamp Equalizer setting ?
By alexander121 in forum AudioReplies: 0Last Post: 25th Jul 2015, 07:38 -
FFMPEG QUESTION :How do I take 10bit jpeg with FFMPEG?
By Jamaika in forum Video ConversionReplies: 10Last Post: 6th Jul 2015, 13:41
